Hello. I recently installed a MCOHome MH-411 Touch Panel Switch to control the light in the hallway of my apartment. I configured it so that it would switch to off after 1 second (because there are other non-zwave switches that toggle the same light). However, since the recent upgrade to HA 0.68.1, the switch does not behave correctly anymore (or rather, the controller timeouts).
Expected behaviour (and actual in 0.67):
- Click on the switch in the WebUI.
- State changes from off to on
- Light is turned on (immediately).
- State changes from on to off after 1 second
- Click again on the switch in the WebUI
- Light is turned off.
Actual behaviour
- click on the switch in the WebUI
- State changes from on to off after 1-2 seconds
- Light is turned off after 10 seconds since step 5.
In the logs I see several errors:
(Dropping Command + Cannot find endpoint map)
Also, initializing the zwave after a HA reboot takes forever (it basically waits 10 seconds for every command and timeouts ofc) This wasn’t before 0.67
This is really annoying. Can you help me?
(It is worth noting that I also recently added the Fibaro Door Sensor 2 to the network, around the same time as the upgrade. I thus cannot actually determine whether its the upgrade or the sensor.)
2018-05-10 21:31:44.070 Info, Node005, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2018-05-10 21:31:44.071 Info, Node005, SwitchBinary::Set - Setting node 5 to On
2018-05-10 21:31:44.071 Detail, Node005, Queuing (Send) SwitchBinaryCmd_Set (Node=5): 0x01, 0x0a, 0x00, 0x13, 0x05, 0x03, 0x25, 0x01, 0xff, 0x25, 0x45, 0x5b
2018-05-10 21:31:44.071 Detail, Node005, Queuing (Send) SwitchBinaryCmd_Get (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x25, 0x02, 0x25, 0x46, 0xa6
2018-05-10 21:31:44.073 Detail,
2018-05-10 21:31:44.073 Info, Node005, Sending (Send) message (Callback ID=0x45, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=5): 0x01, 0x0a, 0x00, 0x13, 0x05, 0x03, 0x25, 0x01, 0xff, 0x25, 0x45, 0x5b
2018-05-10 21:31:44.081 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-10 21:31:44.082 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-10 21:31:44.098 Detail, Node005, Received: 0x01, 0x07, 0x00, 0x13, 0x45, 0x00, 0x00, 0x02, 0xac
2018-05-10 21:31:44.098 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x45 received (expected 0x45)
2018-05-10 21:31:44.098 Info, Node005, Request RTT 24 Average Request RTT 32
2018-05-10 21:31:44.098 Detail, Expected callbackId was received
2018-05-10 21:31:44.099 Detail, Expected reply was received
2018-05-10 21:31:44.099 Detail, Message transaction complete
2018-05-10 21:31:44.099 Detail, Node005, Removing current message
2018-05-10 21:31:44.100 Info, Node005, Sending (Send) message (Callback ID=0x46, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x25, 0x02, 0x25, 0x46, 0xa6
2018-05-10 21:31:44.110 Detail, Unsolicited message received while waiting for ACK.
2018-05-10 21:31:44.116 Detail, Node005, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x05, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x20, 0x03, 0xff, 0x45
2018-05-10 21:31:44.117 Info, Node005, Response RTT 10 Average Response RTT 268
2018-05-10 21:31:44.117 Error, Node005, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_BASIC endpoint 1
2018-05-10 21:31:44.118 Detail, Node005, CAN received...triggering resend
2018-05-10 21:31:44.118 Info, Node005, Sending (Send) message (Attempt 2, Callback ID=0x47, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x25, 0x02, 0x25, 0x47, 0xa7
2018-05-10 21:31:44.126 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-10 21:31:44.127 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-10 21:31:44.165 Detail, Node005, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x05, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x20, 0x03, 0x00, 0xba
2018-05-10 21:31:44.165 Info, Node005, Response RTT 46 Average Response RTT 157
2018-05-10 21:31:44.166 Error, Node005, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_BASIC endpoint 1
2018-05-10 21:31:44.195 Detail, Node005, Received: 0x01, 0x07, 0x00, 0x13, 0x47, 0x00, 0x00, 0x08, 0xa4
2018-05-10 21:31:44.195 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x47 received (expected 0x47)
2018-05-10 21:31:44.195 Info, Node005, Request RTT 76 Average Request RTT 54
2018-05-10 21:31:44.195 Detail, Expected callbackId was received
2018-05-10 21:31:49.546 Info, Node005, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2018-05-10 21:31:49.546 Info, Node005, SwitchBinary::Set - Setting node 5 to On
2018-05-10 21:31:49.547 Detail, Node005, Queuing (Send) SwitchBinaryCmd_Set (Node=5): 0x01, 0x0a, 0x00, 0x13, 0x05, 0x03, 0x25, 0x01, 0xff, 0x25, 0x48, 0x56
2018-05-10 21:31:49.547 Detail, Node005, Queuing (Send) SwitchBinaryCmd_Get (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x25, 0x02, 0x25, 0x49, 0xa9
2018-05-10 21:31:54.107 Error, Node005, ERROR: Dropping command, expected response not received after 2 attempt(s)
2018-05-10 21:31:54.107 Detail, Node005, Removing current message
2018-05-10 21:31:54.107 Detail, Node005, Notification: Notification - TimeOut
2018-05-10 21:31:54.119 Detail,
2018-05-10 21:31:54.119 Info, Node005, Sending (Send) message (Callback ID=0x48, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=5): 0x01, 0x0a, 0x00, 0x13, 0x05, 0x03, 0x25, 0x01, 0xff, 0x25, 0x48, 0x56
2018-05-10 21:31:54.128 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-10 21:31:54.149 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-10 21:31:54.157 Detail, Node005, Received: 0x01, 0x07, 0x00, 0x13, 0x48, 0x00, 0x00, 0x03, 0xa0
2018-05-10 21:31:54.157 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x48 received (expected 0x48)
2018-05-10 21:31:54.157 Info, Node005, Request RTT 37 Average Request RTT 45
2018-05-10 21:31:54.158 Detail, Expected callbackId was received
2018-05-10 21:31:54.159 Detail, Expected reply was received
2018-05-10 21:31:54.159 Detail, Message transaction complete
2018-05-10 21:31:54.160 Detail,
2018-05-10 21:31:54.160 Detail, Node005, Removing current message
2018-05-10 21:31:54.161 Detail, Node005, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x05, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x20, 0x03, 0xff, 0x45
2018-05-10 21:31:54.161 Error, Node005, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_BASIC endpoint 1
2018-05-10 21:31:54.162 Detail,
2018-05-10 21:31:54.162 Info, Node005, Sending (Send) message (Callback ID=0x49, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=5): 0x01, 0x09, 0x00, 0x13, 0x05, 0x02, 0x25, 0x02, 0x25, 0x49, 0xa9
2018-05-10 21:31:54.170 Detail, Node005, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-10 21:31:54.171 Detail, Node005, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-10 21:31:54.187 Detail, Node005, Received: 0x01, 0x07, 0x00, 0x13, 0x49, 0x00, 0x00, 0x02, 0xa0
2018-05-10 21:31:54.187 Detail, Node005, ZW_SEND_DATA Request with callback ID 0x49 received (expected 0x49)
2018-05-10 21:31:54.188 Info, Node005, Request RTT 25 Average Request RTT 35
2018-05-10 21:31:54.188 Detail, Expected callbackId was received
2018-05-10 21:31:55.142 Detail, Node005, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x05, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x20, 0x03, 0x00, 0xba
2018-05-10 21:31:55.143 Detail,
2018-05-10 21:31:55.143 Info, Node005, Response RTT 981 Average Response RTT 569
2018-05-10 21:31:55.143 Error, Node005, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_BASIC endpoint 1
2018-05-10 21:32:04.163 Error, Node005, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-05-10 21:32:04.163 Detail, Node005, Removing current message
2018-05-10 21:32:04.163 Detail, Node005, Notification: Notification - TimeOut
