Hello
can any kind person help me with this problem.
I am a total beginner with home assistant and hassio.
I have installed hassio on a nuc with the nuc image.
I’ve put in a z-wave stick and configured it, and have been able to add things without problems. Then I put in a conbee zigbee stick and configured it using: deconz. I have activated the stick by going to the gateway and activating home assistant. The problem is that when I try to add things to zigbee, it does not work at all. I click on a new sensor, then I activate the sensor so it is in par mode, but nothing happens (never click next)
The sensors I want to add are: MCT340E visonic (made by Saga / Hughes) I’ve seen others succeed adding them but how? then i have xiaomi fire alarm and bosch motion sensor that also needs to be added, i suppose there will be the same problem with this?
Is there anyone who can help me?
(I’m a real noob so please explain in detail how to do things)
//Sincerely
