MCZ Natural Lame compatibility check - board CS12253B LC (PIC32MX460F512L)
Hi everyone,
I have an MCZ Natural Lame pellet stove and I'd like to connect it to Home Assistant, most likely using the micronova_controller project (philibertc/micronova_controller on GitHub), which talks MQTT to many Micronova-based pellet stove mainboards.
Before ordering parts, I'd like to confirm compatibility with my exact mainboard. Details:
  • Board silkscreen reference: CS12253B LC
    • Main MCU: PIC32MX460F512L
    • Secondary chip near the connectors: marked 387STP
    • Connectors visible on the board: J3 (RJ11/RJ12 jack), EXP, COM, PWM headers, a USB-A port (J11/J22), and screw/spade terminals labeled FUMI, COC, DP, NTC1/2/3, PLT, DEB, IN1/IN2, FAN1/FAN2, SIC1/SIC2/SIC3, V3V, COC, ALL.
      Has anyone here connected a board with this exact CS12253B LC reference, or an MCZ Natural Lame stove specifically, to Home Assistant? I'd mainly like to know:
  1. Which connector is the correct serial port for the Micronova protocol (the RJ11 jack at J3, or another unlabeled header)?
  2. Whether the 3.3V/5V logic level and wiring match other documented MCZ boards..
    I already posted the same question on the micronova_controller GitHub Discussions, but I'd love to get more eyes on it here too. I can post close-up photos of any connector if that helps. Thanks a lot!
