Hi!
There is any way to add an icon inside a title or name for a card?
Thanks!
Hi!
Thanks!
You may mimic a card’s header by adding a markdown card with an icon & title to your card inside a seamless stack card like “stack-in-card”.
Yes, but I need the name/title, not a different card
Something easy
You asked “how to add an icon to card’s title”.
Since only some conventional cards (like Entities; may be - ONLY Entities) do support an icon inside a title - you need to achieve it by other way.
Yes… I thought that there is something like from the official HA
Everything described in docs.
If it is not - in 99% it is unsupported, we need to find “ways”.
I was doing this but found that markdown cards load after almost everything else, so it creates unpleasant jumpiness on page load.
I’ve settled for using emojis instead of MDI icons for now but would also like to find a way to use MDI icons in stack title fields.
I forgot about the style content, wow, yes, true. I will try something. Thanks for remebering me this.
I was able to use the information you provided (and our below conversation) and this stack overflow post to come up with a solution I thought I should document and share. Instead of using a URL to an image you can instead encode an SVG icon.
Copy SVG (next to download).Insert SVG. Copy the result from Ready for CSS..card-header:before --icon field as shown below, removing background-image: from the beginning.Using the following card config, with a stack inside a custom:mod-card inside a stack.
type: vertical-stack
cards:
- type: custom:mod-card
card:
title: Security
cards:
- type: tile
entity: lock.front_door_ble
card_mod:
style:
':first-child$': |
.card-header {
display: flex !important;
justify-content: flex-start !important;
gap: 12px;
padding: 16px !important;
.card-header:before {
width: 32px;
--icon: url("data:image/svg+xml,%3Csvg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 24 24'%3E%3Ctitle%3Eab-testing%3C/title%3E%3Cpath d='M4 2A2 2 0 0 0 2 4V12H4V8H6V12H8V4A2 2 0 0 0 6 2H4M4 4H6V6H4M22 15.5V14A2 2 0 0 0 20 12H16V22H20A2 2 0 0 0 22 20V18.5A1.54 1.54 0 0 0 20.5 17A1.54 1.54 0 0 0 22 15.5M20 20H18V18H20V20M20 16H18V14H20M5.79 21.61L4.21 20.39L18.21 2.39L19.79 3.61Z' /%3E%3C/svg%3E");
-webkit-mask: var(--icon);
mask: var(--icon);
-webkit-mask-repeat: no-repeat;
background: var(--primary-text-color);
content: '';
Edit: this method no longer works well with newer versions of card-mod on slower devices. See below for better method using button-card.
It will work for sure if you wrap the card into mod-card.
Ofc you need to edit a path to the header element.
Entities card has a native “icon” option:
What do you mean by wrap the card into mod-card?
Huh. I should have just done that in the first place.
Also I figured out how to color the icon so I guess my solution would work now for custom icons, I’ll update my previous comment.
Check the link to my post in the card-mod thread.
Added examples for cards w/o ha-card.
Note that there not only a path to the header element was altered - a “margin-top” property was changed too, there is a difference between headers for cards like Entities & cards like vertical-stack…
This is interesting. Will check it.
Well, I am not a CSS expert, also learning))).
Thanks! I’ll update my previous comment again with the new solution.
Edit: nevermind. Wrapping the entire stack in a custom:mod-card does let you apply card-mod stylings to stacks, but it doesn’t seem to apply on page load and doesn’t apply until I go into edit mode.
Edit again: nevermind again, it was because I didn’t wrap the whole thing in another stack.
Well, after these “edits” have you got positive results with mod-card? ))
Haven’t checked your solution yet…
Yup! Thanks for your help. I’m going to update my dashboards to use this method to add icons to all of my stack titles later tonight.
this is super interesting! thanks for re-editing and documenting the final solution
I’ve actually been having some problems with my method on newer versions of card-mod on my craptastic fire tablets, as the changes are not applied until everything else loads and causes the unpleasant jumpiness I was trying to avoid. At some point I want to try creating a custom card for section titles so styles can be applied before rendering to prevent jumpiness on page load.
I’m switching to using button-card for custom titles. It’s much more performant than using card-mod to modify entities titles.
type: custom:button-card
icon: mdi:shield-key
layout: icon_name
styles:
card:
- background-color: var(--background-color)
- padding: 6px
icon:
- height: 32px
- width: 48px
name:
- font-weight: 500
- font-size: 24px
- text-align: left
grid:
- grid-template-columns: min-content min-content
