Hello
I have Sonoff POWR320D (Firmware: 1.1.1)
SonoffLAN: 3.6.0
Device provides Power, Current and Voltage entities.
Energy dashboard in HA requires Energy entity
(having device class=energy, state_class=total_increasing)
I tried few ways to get energy from power.
One i tried is as follow:
- platform: integration
source: sensor.sonoff_10017fa545_power
name: Sensor Terrace Heater energy_spent
unit_prefix: k
round: 2
Issue: However, this gives wrong result. Numbers are almost double then actual energy usage.
Another method i tried:
utility_meter:
powr320d_daily_energy:
cycle: daily
Issue: This entity is not shown in Energy dashbaord.
Following is the detail about entity. May be since unit is W, it is not showing in energy dashboard.
state_class: total_increasing source: sensor.sonoff_10017fa545_power status: collecting last_period: 147065.97 last_valid_state: 2241.29 meter_period: daily cron pattern: 0 0 * * * last_reset: 2024-02-23T18:30:00.015233+00:00 unit_of_measurement: W
And also it gives too much high reading than actual usage.
Actual usage was 13kwh, while showed 62kwh when i checked entity properties.
Method 3 Tried:
template:
- sensor:
- name: "Heater Energy"
unique_id: "heater_energy"
unit_of_measurement: "kWh"
state_class: "total_increasing"
device_class: "energy"
state: >
{{ (states('sensor.sonoff_10017fa545_power') | float / 1000) * (1 / 60) }}
attributes:
last_reset: "1970-01-01T00:00:00+00:00"
Issue: It shows double usage than actual usage in Energy dashboard.
Error Log: Entity sensor.heater_energy from integration template has state class total_increasing, but its state is not strictly increasing.
Please suggest, what is the right method to get energy from power and usable under energy dashboard.
