Measure switchON-time
I’m just starting with esphome, so maybe I missed some info. Im trying to measure the number of seconds a switch is in ON-state. So I store a timestamp at turning on, another one at turning off and now I’m trying to log the difference of my two timestamps:
globals:
  - id: timeON
    type: long int
    restore_value: no
  - id: timeOFF
    type: long int
    restore_value: no
i2c:
  sda: GPIO4
  scl: GPIO5
  scan: True
pcf8574:
  - id: 'pcf8574_1'
    address: 0x20
    pcf8575: False
time:
  - platform: sntp
switch:
  - platform: gpio
    pin:
      pcf8574: pcf8574_1
      number: 6
      mode: OUTPUT
      inverted: True
    on_turn_on:
      - logger.log: "turning on"
      - lambda: |-
          timeON = id(sntp_time).now().timestamp;
    on_turn_off:
      - logger.log: "turning off"
      - lambda: |-
          timeOFF = id(sntp_time).now().timestamp;
          ESP_LOGD('TEST', "Difference in seconds: %d", difftime(timeOFF, timeON) );
So I have two questions:
a) Is this the way to get my switch-ON-time? Or does a better way exist?
b) What do I have to do im my statement, because this does not compile.
Error shown:
src/main.cpp:553:14: error: invalid conversion from 'time_t {aka long int}' to 'esphome::globals::GlobalsComponent<long int>*' [-fpermissive]
       timeON = sntp_time->now().timestamp;
The error is because timestamp is of type time_t which is unsigned. I would define timeON and timeOFF as type: time_t and that should fix your compile issue.
You could alternatively use the History Statistics Sensor which would do all the work for you.
Nice feature, thanks for the link. But in my case I prefer to handle this only on my esp8266.
tomeps
No, I did try several types. But I solved it, it was a real silly mistake: instead of
I have to use:
id(timeON) = sntp_time->now().timestamp;
Thnaks for pointing me in the right direction!
tomesp
