Measurement state_class and statistics are not working
I can’t for the life of me work out how to provide the state_class and last_reset properties to Home Assistant such that users can access statistics for the values.
I’ve even tried overly verbose logging (original source):
    @property
    def state_class(self):
        """Return the state class if relevent"""
        measurement = getattr(self.__statistic, "measurement", False)
        if measurement:
            _LOGGER.debug("Is measurement class")
            return "measurement"
        else:
            _LOGGER.error("Is not measurement class")
            return None
And I’m never seeing those properties being accessed by Home Assistant.
Of course - this means that there are no statistics available when trying to access them in lovelace:
It seems setting a state_class of measurement does not yet work.
I assume statistics has been pre-documented before being implemented?
Does anybody know if statistics is still coming, or this is a bug?
Does your sensor extend the Entity class or the SensorEntity class?
Thank-you @anotherjulien - it’s SensorEntity link
Is there any documentation I can refer to? Is the RestoreEntity the issue?
class NSWCovidEntry(RestoreEntity, SensorEntity):
    """Represent a NSW Covid Statistic."""
    def __init__(
        self,
        statistic,
        """Set up NSW Covid entity."""
        self.__statistic = statistic
It might make sense that not using a built-in device_class along with its default unit_of_measurement could be the problem, don’t you think?
The only default device_class you seem to use is timestamp and I’m not even sure how it would make sense to extract statistics from this type of measurement. :slightly_frowning_face:
Just to be on the safe side, I’d try to set last_reset to dt_util.utc_from_timestamp(0) (with from homeassistant.util import dt as dt_util) instead of None by default, but I’m not sure it makes sense for measurements that are not continually accumulating…
I’m not sure I follow? The default is timestamp - that doesn’t mean that everything (or anything) is the default. (see image in previous post) - the unit of measurement for most of the sensors is “cases” or “doses”
Additionally - I’d like to keep last_reset as the actual last reset value - rather than epoch
What I mean is that except for ISO8601, you only seem to use custom unit_of_measurement
    def unit_of_measurement(self):
        """Return the unit of measurement"""
        if (
            self.__statistic.typeName
            and self.__statistic.typeName is not None
            and self.__statistic.typeName in TIMESTAMP_TYPES
            return "ISO8601"
        if self.__statistic.unit and self.__statistic.unit == "case":
            return "cases"
        if self.__statistic.unit and self.__statistic.unit == "death":
            return "deaths"
        if self.__statistic.unit and self.__statistic.unit == "dose":
            return "doses"
        if self.__statistic.unit and self.__statistic.unit == "test":
            return "tests"
        return self.__statistic.unit
Same with device_class for which you seem to have timestamp or None
    def device_class(self):
        """Return the device class if relevent"""
        if (
            return "timestamp"
        return None
My concern is that HA might only be able to generate statistics for known device_class with suitable unit_of_measurement.
As far as the last_reset, my suggestion is only to replace None in the following; not to return dt_util.utc_from_timestamp(0) systematically.
    def last_reset(self):
        resetting = getattr(self.__statistic, "resetting", False)
        if not resetting:
            return None
        return self.__statistic.published
Indeed. This should change in the next version
