Measuring 0-3.3v on ADC pin?
I think I’ve stumbled onto the fact that the ADC pins on an ESP32 max out at 1v…
How can I accurately measure 0 to 3.3v on a pin?
A voltage divider but surely that would make the low end voltages very small?
Yeah, so what is the problem? :slight_smile:
Just use a voltage divider and do a small calibration for the factor (instead of just calculating it based on the resistor values).
Cool, thanks was just trying to make sure there was no other way to get it done…
Another way - I2C-connected ADC, f.e. widely used 4-channel ADS1115.
From my experience - significantly more precise comparing to ESP ADC input.
try with
attenuation: auto
or
attenuation: 12dB
Ah perfect! I will try that and see how I get on… Thank you!
