I’d like to measure the time (in seconds) between two rising edges on one of the GPIOs.
Theoretically, it’s simple. I check the “timestamp” on the first edge and subtract it from the “timestamp” on the next one.
But there’s a catch… This is a battery-operated device so I need to be in Deep Sleep mode for as long as possible. So after each wake-up (via GPIO), the ESP32 chip must connect to WiFi to download data from Home Assistant or SNTP, and only then can I read the “timestamp”.
And it is the time of connecting to wifi that is the most variable factor. The other thing is that it doesn’t work locally at all. It must have internet access…
esphome:
on_boot:
then:
- lambda: |-
auto time = id(hassio_time).utcnow();
if(id(flag) == 1)
id(flag) = 0;
id(timeON) = time.timestamp;
id(time_between) = (id(timeON) - id(timeOFF));
else
id(flag) = 1;
id(timeOFF) = time.timestamp;
id(time_between) = (id(timeOFF) - id(timeON));
ESP_LOGD("custom", "Time: %d s", id(time_between));
- delay: 3s
- sensor.template.publish:
state: !lambda 'return id(time_between);'
- delay: 3s
- switch.template.publish:
state: !lambda 'return true;'
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxx"
ota:
password: "xxx"
wifi:
ssid: !secret wifi_ssid
fast_connect: true
ap:
ssid: "Esp32-Deep-Sleep-Test"
password: "zbmUTpyTzxXS"
captive_portal:
globals:
- id: timeON
type: int
restore_value: yes
initial_value: '0'
- id: timeOFF
type: int
restore_value: yes
initial_value: '0'
- id: flag
type: int
restore_value: yes
initial_value: '1'
- id: time_between
type: int
restore_value: yes
initial_value: '0'
time:
- platform: homeassistant
binary_sensor:
- platform: gpio
pin:
number: GPIO0
inverted: True
name: "Deep Sleep Sensor test"
update_interval: never
switch:
optimistic: true
name: "Enter Deep Sleep"
optimistic: true
on_turn_off:
then:
- delay: 1s
- deep_sleep.enter:
deep_sleep:
run_duration: 24h
sleep_duration: 24h
wakeup_pin: GPIO0
wakeup_pin_mode: INVERT_WAKEUP
Is it possible to use the internal clock instead? After all, I can rigidly set the run and sleep duration. So the clock must be running during Deep Sleep. Is it possible to use it to read how much time has elapsed between successive ESP wake-ups?
Thanks in advance for any hint
