I don’t get along with HA’s media paths management and need some advice, please:
(and btw. the documentation about media_paths and media_source is not that intuitive to me)
My webcam is taking a snapshot on motion detection and saves it under /media/tapo/last_motion.jpg, which opens in the media browser via Media Sources / Local Media / tapo.
My Samba share path looks like this: \192.168.1.252\media\tapo\last_motion.jpg
My confguriation.yaml:
homeassistant:
allowlist_external_dirs:
- "/media/tapo"
media_dirs:
media: "/media/tapo"
When I set up a picture card or send a notification with attachment to my mobile with the path \media\tapo\last_motion.jpg then no imaging is showing up. So what the heck am I doing wrong?
After trawling through various threads about this topic I finally got it to work by moving the tapocam folder inside the www and adjusting the paths accordingly
snapshot/record service → absolute path ( /config/www/tapocam/last_motion.jpg )
notify service → local path ( /local/tapocam/last_motion.jpg)
homeassistant:
- /config/www/tapocam
media_dirs:
local: /config/www/
Glad you work it out.
I have a nice automation regarding this that might help you further. I use IP Webcam for android and it exposes also entities for light (turns on the phone light) and also night vision. In my hall where the main door is, i also have an LED strip attached to furniture that illuminates the room. I build an automation that is using all these with the following logic:
- when the door or window opens (trigger)
- if we are away or on vacation (conditions)
- Actions:
a) Turn on the hall furniture LED
b) If its after sunset, it will also turn on the phone light to further illuminate the room
c) If its after sunset, it will activate the night vision
d) It will take a snapshot from the camera
e) It will send the snapshot to my phone
f) After one minute it will turn off the lights and night vision
Here is the automation yaml:
alias: Security - Camera Motion
description: ""
- type: opened
platform: device
device_id: 3676cb415ce79ee6e4a170779bcff40f
entity_id: binary_sensor.main_door_sensor_ias_zone
domain: binary_sensor
- type: opened
platform: device
device_id: 6aa9081478a7972d231bc71c1fbeec3b
entity_id: binary_sensor.lr_window_sensor_ias_zone
condition:
- condition: or
conditions:
- condition: state
entity_id: input_select.home_status
state: Away
- condition: state
state: Vacation
- type: turn_on
device_id: 6b4816ffd6c0ba41f7a96caf577f7c7d
entity_id: light.hall_furniture_local
domain: light
- service: switch.turn_on
data: {}
entity_id: switch.192_168_100_7_torch
- if:
- condition: sun
after: sunset
then:
data: {}
entity_id: switch.192_168_100_7_night_vision
else:
- service: switch.turn_off
data: {}
- delay:
hours: 0
minutes: 0
seconds: 3
milliseconds: 0
- service: camera.snapshot
filename: /config/www/s.jpg
entity_id: camera.192_168_100_7
- service: notify.mobile_app_michael
message: Motion Detected at Home
image: /local/s.jpg
title: Security Notification
- delay:
hours: 0
minutes: 1
seconds: 0
milliseconds: 0
- type: turn_off
domain: light
data: {}
data: {}
mode: single
as you can see, i have placed the screenshot in /config/www/ and then for it to be sent i set the path as /local/filenume.extension
The “local” folder is actually the “www” folder inside the config directory.
Hope this helps
Kind Regards
M
