Media mount on nas keeps disconnecting on reboot
I am trying to mount a share on my synology as type “media”. Called “frigate”
This is what the logs says:
[supervisor.mounts.manager] Creating or updating mount: Frigate
23-09-06 22:57:36 INFO (MainThread) [supervisor.mounts.mount] Creating folder for mount: /data/media/Frigate
The problem is after a reboot the mounted share is gone. I have also mounted a share with the type “backup” this one works fine and is still there after a reboot.
The read/write rights are working fine, i am using the same credentials to connect to the share from my phone (as a test).
Frigate is still writing to my local disc but that is probably because something is going wrong with the mounting of the share.
did you ever get this figured out? I have the same issues running HA inside of Linux KVM. Anytime that is rebooted, the external storage I have mounted (via NFS) is disconnected and does not auto-reconnect.
