I do not seem to get my speakers to play local hosted files. I have tried numerous things. The error that I get is:
Logger: homeassistant.components.cast.media_player
Source: components/cast/media_player.py:348
Integration: Google Cast (documentation, issues)
First occurred: 9:38:52 AM (11 occurrences)
Last logged: 9:51:56 AM
Failed to cast media https://[xxx].duckdns.org/test2.mp3 from internal_url (https://[xxx].duckdns.org). Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
Failed to cast media http://[ownIP[/test2.mp3. Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
Failed to cast media https://home-assistant.io/images/cast/splash.png. Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
Failed to cast media \\192.168.178.100\media\Testme2.mp3. Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
Failed to cast media http://192.168.178.100/media/Testme2.mp3. Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
My config:
System Health
arch
aarch64
chassis
embedded
dev
false
docker
true
docker_version
19.03.8
hassio
true
host_os
HassOS 4.10
installation_type
Home Assistant OS
os_name
Linux
os_version
4.19.126-v8
python_version
3.8.6
supervisor
2020.10.1
timezone
Europe/Amsterdam
version
0.117.2
virtualenv
false
Lovelace
dashboards
2
mode
auto-gen
resources
0
I have tried numerous things;
Setting up the external URL to https://[xxx].duckdns.org
TTS seems to create the TTS files on homeassistant, so it is reachable HOWEVER, it does not play the TTS files, due ot the same error.
Home assistant is controllable externally.
I can control Home Assistant via Google Assistant with the google assistant integration
It can cast internet hosted files, so there must be something wrong with my config to reach the home assistant instance…
If you want to play local content, the easiest way is to serve the files over http from the www folder, or a subfolder of the www folder since it is already exposed by the HA webserver as /local.
So, try the following:
Make a subfolder named media in your www folder and place the media file there.
Add this as content_id to your service call:
entity_id: media_player.home_mini
media_content_id: 'http://192.168.178.100:8123/local/media/Testme2.mp3'
media_content_type: music
Gives
Failed to cast media http://192.168.178.100:8123/local/media/Testme2.mp3. Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
Works with https://[myduckdns]/local/media!!!
Also, it is case-sensitive…
Also media browser playing works. Only TTS is a challenge
I’m also having this issue. From time to time, without making any changes, the music play and tts is streaming to my Google Home Mini. But in 99% cases, both options are not working.
The error:
2020-11-13 22:09:41 ERROR (Thread-7) [homeassistant.components.cast.media_player] Failed to cast media ..... from internal_url (https://a....:8123). Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
The URL is available from internal and external access on the same address and port. All other functions related to this device are working.
Home assistant works in mysterious ways…I added some suggested configuration lines in my config.yaml, and later commented it, and deleted it. Then it worked.
Currently streaming mp3 files works like a charm. TTS is still an issue somehow.
For me, media and tts are not working again. They worked for a while, now dead again.
I can assure that every of these files below (masked for privacy) are publicly accessible.
I asked a friend of mine, outside of my local network, to open them, and he could open all files.
## Dettagli registro (ERROR)
Integration: Google Cast ([documentation](https://www.home-assistant.io/integrations/cast), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+cast%22))
First occurred: 12 novembre 2020, 19:17:20 (12 occurrences)
Last logged: 18:19:49
* Failed to cast media https://xxxxxxx:8123/media/music/Aretha Franklin/30 Greatest Hits/1-04 Dr. Feelgood.mp3?authSig=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJkODg3NjYzZGMxMDU0Mjc4OGQ2Zjk1OWZlZDcxZTY2ZSIsInBhdGgiOiIvbWVkaWEvbXVzaWMvQXJldGhhIEZyYW5rbGluLzMwIEdyZWF0ZXN0IEhpdHMvMS0wNCBEci4gRmVlbGdvb2QubXAzIiwiaWF0IjoxNjA1MjA1MDUzLCJleHAiOjE2MDUyMDUzNTN9.Rd9HO1N2uBZLqGTdDdaxdkjpQWPtJJ4KZBn6EES-T7k from internal_url (https://xxxxxx:8123). Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
* Failed to cast media https://xxxxxxxx:8123/media/music/Aretha Franklin/30 Greatest Hits/1-04 Dr. Feelgood.mp3?authSig=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJkODg3NjYzZGMxMDU0Mjc4OGQ2Zjk1OWZlZDcxZTY2ZSIsInBhdGgiOiIvbWVkaWEvbXVzaWMvQXJldGhhIEZyYW5rbGluLzMwIEdyZWF0ZXN0IEhpdHMvMS0wNCBEci4gRmVlbGdvb2QubXAzIiwiaWF0IjoxNjA1MjA1MDU3LCJleHAiOjE2MDUyMDUzNTd9.m9F8IigkccRWX7XtoAwyUORGAMqH_yCLQ96WJA42k-Y from internal_url (https://xxxxxxxx:8123). Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
* Failed to cast media https://xxxxxxx:8123/api/tts_proxy/68377bdbe20b62e2df883e3d5b1120bcc77973db_it_-_google_translate.mp3 from internal_url (https://xxxxxxx:8123). Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
* Failed to cast media https://xxxxxxxxx:8123/media/music/Gorillaz/Gorillaz/05 Clint Eastwood.mp3?authSig=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJkODg3NjYzZGMxMDU0Mjc4OGQ2Zjk1OWZlZDcxZTY2ZSIsInBhdGgiOiIvbWVkaWEvbXVzaWMvR29yaWxsYXovR29yaWxsYXovMDUgQ2xpbnQgRWFzdHdvb2QubXAzIiwiaWF0IjoxNjA1NzE5OTgxLCJleHAiOjE2MDU3MjAyODF9.A9VlA_QQRh6kItrjmf4SOvKFH4PE61Gy71of45s36S4 from internal_url (https://xxxxxx:8123). Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
* Failed to cast media https://xxxxxxxx:8123/media/music/Gorillaz/Gorillaz/05 Clint Eastwood.mp3?authSig=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJkODg3NjYzZGMxMDU0Mjc4OGQ2Zjk1OWZlZDcxZTY2ZSIsInBhdGgiOiIvbWVkaWEvbXVzaWMvR29yaWxsYXovR29yaWxsYXovMDUgQ2xpbnQgRWFzdHdvb2QubXAzIiwiaWF0IjoxNjA1NzE5OTg5LCJleHAiOjE2MDU3MjAyODl9.zq7pBD9-q1vrpfT8DLsYS9-CDzJ2ftluIlOfUQa_6ok from internal_url (https://xxxxxxx:8123). Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
Did you get a solution to “Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address”?
My TTS works fine; have included media dirs; externally accessible dirs; allowed external URLs, but cannot get any media files to cast to my speakers - only the “plink” sound and then silence…
I have the same issue with my Google Home mini. TTS and casting media via HA is not working with the unreachable error message. Although, the HA is reachable via duckdns along with Google Assistant is linked and working correctly with HA. Anyone managed to find a working solution? Thanks.
I’m having the same issue as well. It started happening today, worked fine yesterday. I didn’t make any changes either to home assistant or to my cast devices.
I can’t cast TTS, music or videos. Getting the same loglines as mentioned above:
Failed to cast media https://r6---sn-uxaxovg-5god.googlevideo.com/videoplayback..... Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
Failed to cast media https://www.home-assistant.io/images/cast/splash.png. Please make sure the URL is: Reachable from the cast device and either a publicly resolvable hostname or an IP address
Hi.
I have similar issue.
When I turn on the media player (Nest Mini) through the HomeAssistant card, this error occurs:
First occurred: 22:52:42 (1 occurrences)
Last logged: 22:52:42
