Media_play.play_media service and Medial Folder Integration
If I am incorrect here, please correct me, but from what I have tried myself and read from a post like Media_player path, Home Assistant OS server’s Media folder is not directly accessible by Media_play.play_media function.
So my feature request is please make Content_ID to either auto populated drop down box or popup window with a select file browser to the content of files in the Media folder.
Than you
Hi Tom,
Thank you for the reference. My setup is Home Assistant OS. I dropped my MP3 & WAV files into Media Folder via Samba and I see them in the Media Browser. The files are called ring.wav & ring.mp3
So I’d assume one of the following should work, but none works for me.
media-source://media_source/ring.wav
media-source://media_source/local/ring.wav
media-source://media_source/media/ring.wav
media-source://media_source/local/media/ring.wav
Did you add this to your configuration.yaml file and restart Home Assistant?
media_source:
And if the file is in the root of your /media folder, this should be the correct one:
I wonder if Sonos as a target somehow won’t make media-source:// protocol to not work?
So you did this?
or do you have this in your configuration.yaml file:
default_config:
I have added media_source: and didn’t reboot initially so I did but still the same.
Yes I do see default_config: at the first line.
Then you don’t need to add media_source: .
Not sure why it isn’t working.
It sounds like even on Sonos, this should work. So I can only think/blame on my setup. I have it ProxMox Virtual Machine. I think I still have Rasberry Pi version, so I will try test to see if that works since I didn’t try media-source protocol before on it either.
Thank you very much for your help!
