After converting all my alexa-ttl scripts and automations over to notify.alexa_media (without issue, thank you), I wish to continue this transition by setting some volume levels on the echo-speak. Is there a new format/syntax for setting volume now?
Never mind. I think I found a workaround for my scripting/automations. Using two services separated by a two second pause seems to reliably work if you don’t mind the beep at the beginning. The cludge-code sample looks like this:
dash_button_test:
alias: Dash Button Test
sequence:
- service: media_player.volume_set
entity_id: media_player.406_living_room_echo_dot
volume_level: '0.8'
- delay: '00:00:02'
- service: notify.alexa_media
- media_player.406_living_room_echo_dot
message: Hey Dude, how is your programming going?
type: tts
Thanks alos using volume_set in my play_radio script.
I have ported this script over from my old automation system and have the folllowing now:
alias: Alexa Play Radio
sequence:
- service: media_player.play_media
entity_id: '{{ alexa_device }}'
media_content_id: '{{ alexa_station }}'
media_content_type: TUNEIN
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
data_template:
volume_level: '{{ alexa_volume }}'
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
data_template:
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
data_template:
- condition: template
value_template: '{{ alexa_show_startpage == 1 }}'
- delay:
hours: 0
minutes: 0
seconds: 4
milliseconds: 0
media_content_type: custom
media_content_id: zeige start bildschirm
mode: parallel
max: 20
The multiple call to volume set is because i had the issue on my old system that the new volume can just be set when alexas was playing → thus setting it multiple times solved the issue on my old system.
Now i have the following error in my logs often:
2022-04-01 11:52:37 WARNING (MainThread) [alexapy.helpers] alexaapi.set_volume((<alexapy.alexaapi.AlexaAPI object at 0xffff78056ee0>, 0.32), {}): An error occured accessing AlexaAPI: An exception of type AlexapyTooManyRequestsError occurred. Arguments:
('Too Many Requests',)
So my question is:
Is your approach (set voume, wait 2 secs & do alexa mediaplayer action) reliable and also working?
thank you
Thanks for this sample code, i spring boarded off your code here and added a follow up to return the echo to a reasonable volume after the announcement and also reduced some unnecessary dead time in-between the first volume change the and announcement.
alias: Close the doors
sequence:
entity_id: media_player.echo_studio
volume_level: '1'
- delay: '00:00:01'
- media_player.echo_studio
message: Close the fooking door
type: tts
- delay: '00:00:01'
volume_level: '0.5'
mode: single
I did another work on the previous examples. I store the initial volume level and restore it after the announcement. I created an input_number helper to do so (hint: The variables feature of a script may be more straight forward).
I made some surprising observations. The delay sets the length of time until the next adjustment of the volume is done. The spoken language is independent from this.
Hence, the length of the delay has to match the length of the spoken text. To get a little pause and not have to match the millisecond, I append a short pause to the text by the break tag of SSML. Just play a little with those values to get a nice blending of spoken words and the playing music.
Another observation is, to call the announcement first and then to push up the volume. Doing it the other way results in an ugly climax of the music just before the announcement.
sequence:
- service: input_number.set_value
value: "{{ state_attr('media_player.beta', 'volume_level') | default(0.5, true) | float }}"
entity_id: input_number.previous_volume_of_beta
target: media_player.beta
message: >-
<break time="500ms"/> It's cold outside. Please shut the door! <break
time="1500ms"/>
type: announce
volume_level: 0.8
entity_id: media_player.beta
- delay:
hours: 0
minutes: 0
seconds: 6
volume_level: "{{ states('input_number.previous_volume_of_beta') | float }}"
mode: single
icon: mdi:door-open
Perfect! Elmar. Thank you very much!
But in my case it gave error and did not go back to the previous volume.
So I used it like this, and it’s working perfectly!
alias: Alexa diz Ola Paty
sequence:
- service: notify.alexa_media_echo_show_capo
target: media_player.echo_show_capo
message: >-
<break time="500ms"/> Olá, estranha! Que bom que você apareceu por aqui!
Seja bem vinda! Estou ligando a TV pra vocĂŞ! Se quiser pode me chamar
dizendo, "Alexa!", ligue o ar condicionado, ou, desligue a TV! A
temperatura agora está
{{states("sensor.openweathermap_temperature")|round(0)}} graus! A
PrevisĂŁo para amanhĂŁ Ă© de {{states("sensor.weather_conditions_pt")}},
com temperatura mĂnima de
{{(state_attr('weather.openweathermap','forecast')[1].templow)|round(0)
}}, e máxima de
{{(state_attr('weather.openweathermap','forecast')[1].temperature)|round(0)
}} graus. Fique Ă vontade e sinta-se em casa! <break time="1500ms"/>
type: announce
volume_level: 0.8
entity_id: media_player.echo_show_capo
- delay:
hours: 0
minutes: 0
seconds: 34
milliseconds: 0
volume_level: 0.4
mode: single
icon: mdi:cast-audio
Yes the timing matters a lot and even may depend upon the device. I am still working upon an improved version. There are significant differences in the timing between announce and tts. tts in fact needs two delays. Even for tts I start the speaking before controlling the volume flow contrary to the above scripts.
Sorry guys for not adding an update after my first post above.
Here are my current scripts:
Play radio:
sequence:
data_template:
entity_id: "{{ alexa_device }}"
volume_level: "{{ alexa_volume }}"
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
media_content_id: "{{ alexa_station }}"
value_template: "{{ alexa_show_startpage == 1 }}"
- delay:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
mode: parallel
max: 20
To call it:
- service: script.turn_on
entity_id: script.alexa_play_radio
variables:
alexa_device: media_player.badezimmer
alexa_volume: 0.23
alexa_station: Life Radio Oberösterreich
alexa_show_startpage: 1
Announcment single:
alias: Alexa AnkĂĽndigung Einzeln
sequence:
- variables:
old_volume: "{{ state_attr(alexa_device , 'volume_level')|float(0) }}"
data_template:
volume_level: "{{ alexa_volume_speak }}"
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
- service: "{{ alexa_service }}"
message: "{{ alexa_message }}"
type: announce
method: all
- delay:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
data_template:
volume_level: "{{ old_volume }}"
mode: parallel
max: 20
to call it:
- service: script.alexa_announce
data_template:
alexa_service: notify.alexa_media_badezimmer
alexa_volume_speak: 0.8
alexa_message: Achtung, Achtung! Wasser wird heiĂź in 5 4 3 2 1 0...
Have fun
So far my final service. It works for the types tts and announce. It has been tested with Echo 4th generation and Echo Dot 3rd generation.
alias: Alexa say
description: Say something with an Alexa device (tts or announce)
variables:
# length of a pause before speaking, to adjust the volume without noise
pause: "{{ 1.7 if type == 'tts' else 0.0 | float }}"
# the gong replaces the pause in case of `announce`
gong: "{{ 1,7 if type == 'announce' else 0.0 | float }}"
# store the original volume to reset it later
# set a default because of the empty value, when no music is playing
reset: "{{ state_attr(target, 'volume_level') | default(0.5, true) | float }}"
fields:
message:
description: the message (SSML)
example: <amazon:effect name="whispered">Please close the door.</amazon:effect>
required: true
type:
description: tts or announce
example: tts
required: true
description: the target devise as a string
example: media_player.beta
required: true
volume:
description: the volume of the speach
example: 0.7
required: true
duration:
description: the length of the speach in seconds
example: 3.3
required: true
sequence:
# start up the speaking before controlling the volume, to avoid a moment of yelling music
target: "{{ target }}"
# but delay the words until the volume is adjusted in case of `tts`
# in case of `announce` the pause is zero as the gong did this job
message: >-
<break time='{{ pause + 0.2 | float }}s'/> {{ message }} <break
time='1s'/>
type: "{{ type }}"
# a pause in case of `tts`
# zero in case off `announce`, we want a loud gong
- delay:
hours: 0
minutes: 0
seconds: "{{ pause | float }}"
milliseconds: 0
# tune up
volume_level: "{{ volume }}"
entity_id: "{{ target }}"
# tuned for the length of the spoken text
# plus the length of gong if any
- delay:
hours: 0
minutes: 0
seconds: "{{ gong + duration | float }}"
milliseconds: 0
# reset the old volume
volume_level: "{{ reset | float }}"
# wait until Alexa adjusted to the old volume before doing the next one in the queue
- repeat:
while:
value_template: >-
{{ (reset | float) != (state_attr(target, 'volume_level') | float) }}
sequence:
- delay:
hours: 0
minutes: 0
seconds: 1.5
milliseconds: 0
# TODO: prevent an endless loop
mode: queued
max: 5
icon: mdi:bullhorn
Use announce:
type: announce
message: >-
<p>It's <emphasis level="strong">cold</emphasis> outside.</p>
<p><amazon:effect name="whispered">Please close the door!</amazon:effect></p>
volume: 0.8
duration: 4.7
Use tts:
type: tts
message: >-
volume: 0.8
duration: 4.7
Limitations
My above script is in queue mode. Running it in parallel mode with parallel calls would end up in a mess. The increased volume of the first run would be taken as the original volume of the parallel run.
The queue if fine for one device, but I also can’t speak to multiple devices at the same time, because the queue is on the level of the script. I use it to remind to close an open door. It would make sense to talk into both rooms at the same time. Ideally the queue should work on per target level. Any idea how to improve this?
I am using my script “Alexa Ankündigung Einzeln” in parallel mode, and it’s working for multiple calls from another script with an 500ms delay. All alexas have the correct volume after the run.
Ahh, got you. You mean multiple calls to the same entity. I think your approach with queued is a good workaround. Have now impolemeted your approach instead of mine. Finally alexa isn’t noise when music is playing before the speak. Thanks a lot!
sorry, i am a bit dumb, but where do u put these scripts?
The script (first one) you put it in Settings → Automations → Scripts.
And then call it like the examples given from an automation.
and what if I want to play a sound instead of a speach?
and want it to be played every 10 seconds while a certain state is active?
I think you can do it like I did with a light, use repeat in an automation:
- repeat:
sequence:
- service: light.toggle
metadata: {}
data: {}
entity_id:
- light.beleuchtung_keller
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
until:
- condition: device
device_id: xxx
domain: alarm_control_panel
entity_id: xxx
type: is_disarmed
I have implemented recurring notifications with an time helper which get’s set in the future when the notification should be repeated. As trigger is use this time helper than in my automation. To disable it add another condition from your ex.: light.
Hi there,
thanks for your work. I got everything running but as long as the “Kids Mode” is activated the script won’t play the announcement on that device. The volume adjustment works but not the announcement itself.
Do someone knows a work around for that?
Sorry, i am dont using the kids mode.
Thank you for the scripts. The scripts themselves work well but I am having an issue with the media player information not updating in HA in a way as to make this usable.
The media information (volume, track, etc.) doesn’t update in HA unless I change it in HA. I’m monitoring the state of the volume using the developer tools templates section and see it changing in real-time when changing the volume via HA, but not at all when changing via Alexa app or voice.
For example: If I play something on my Echo Speaker using the HA media player, the track info updates as expected, and the volume updates almost instantly when changed from the HA dashboard. However, if I play the track (or change the volume) by speaking to the Echo device or by using the Alexa app on my phone, that change isn’t reflected in HA until I somehow interact with the Echo device from within HA.
The way I want to use the script (and I imagine the way it was intended to be used) is to temporarily raise the volume for the announcement and then lower it again after the announcement is done. But, if I start playing music at volume 40% with my voice and then an announcement happens, the script doesn’t pick up that the volume is 40%, it just grabs the last known (to HA) volume, which is likely 80% from the last announcement. So after the announcment, the volume doesn’t go back to what it was.
Am I missing some setting? How do I make HA update the alexa media information quicker?
