Media Player automation only works once
I have set up an Aqara button / ZHA automation that with a single press will play a radio station for 30 seconds then stop (see yaml below) - and it works as expected. But if after a few minutes of silence I press the button once again, nothing happens - unless I go back in and change the radio station within the automation first. I tried changing the final service: media_player.media_stop to service: media_player.media_pause but that didn’t help.
Any ideas as to where I am going wrong?
TIA
alias: Aqara Zigbee Button Music
description: ""
use_blueprint:
  path: apollo1220/aqara_zigbee_button.yaml
  input:
    button_id: a3f9cbb24f18b9a67de18761c8e44a86
    press_action:
      - service: media_player.play_media
          entity_id: media_player.sitting_room
          media_content_id: "59:0"
          media_content_type: track
        metadata:
          title: BBC Radio 4 (London, UK FM 93.5 English)
          thumbnail: >-
            http://192.168.2.103:9330/api/image/afd611ddf80b5dce68aa13b8e9e99aff8bf23d351d0918d67f032e52c91c6dc24882ed6107bcb78f714d78cf03afae00bc229db4b9cf8f60651267fade0ef77743277e9d6b9cc1a02b31ceb2c964915e4716542f56b804f4ecbb5415cccf009ce1b807f055c2a182a450403dbdbaa048?scale=fit&width=500&height=500
          media_class: track
          children_media_class: null
          navigateIds:
            - media_content_type: library
              media_content_id: "56:2"
      - delay:
          hours: 0
          minutes: 0
          seconds: 30
          milliseconds: 0
      - service: media_player.media_pause
        data: {}
    double_press_action: []
metadata and everything under it should be under data. I.e. indent it all by 2.
Thanks @petro ; I changed the indentation, but that didn’t fix it. I thought that it might be a case of the media player not being “released” somehow, and then saw that I was starting the music through Play media on a media player but ending it on a Call Service. By putting the start and end on Call Service I am now able to re-start the music (for 30 seconds) more than once. Great news.
However, whilst Play Media allows you to specify what music to play, using Call Service doesn’t; would there be a syntax where I can set this?
Also, how might I set the volume level?
TIA
This is my current yaml
alias: Aqara Zigbee Button Apollo
description: ""
use_blueprint:
  input:
    press_action:
      - service: media_player.media_play
        data: {}
          entity_id: media_player.16_mbpro
      - delay:
          hours: 0
          minutes: 0
          seconds: 30
          milliseconds: 0
      - service: media_player.media_stop
        data: {}
          entity_id:
            - media_player.16_mbpro
          entity_id: ""
          media_content_id: ""
          media_content_type: ""
        metadata: {}
