In landscape mode, on both the Android app and in a web browser, when you turn on a media player, the power button disappears. To turn it off, you have to hit the three dots and then turn it off from within there.
In portrait mode, it behaves as expected, and the power button remains available on the card to turn the media player off without having to enter the other menu.
This is happening across multiple devices and multiple browsers. Is anyone else seeing this, and if so, is there a fix??
EDIT: It looks like it only happens when the side bar is collapsed. If the side bar is expanded, the control works as expected. On my dashboard, when it is expanded there are 3 columns of media players. When collapsed, there are 4.
EDIT 2: Upon further investigation, it appears to only happen on devices with high enough resolution that cause the number of columns of media players to change. On devices with lower resolution where collapsing the sidebar still results in only 3 columns of media players, the media players function as expected. As soon as there are 4 columns of media players, the power button disappears. Certainly this must be a bug?
Thanks!
