Hi
I had a script that was working fine some time ago and I’ve just got around to looking at automating it again and it seems it’s stopped working. The script was to play a rtsp stream from a local camera to a kodi system.
I had some problems using the media_player.play_media service with Kodi a few weeks ago and I resorted to using the kodi.call_method instead. I will probably figure the JSON out to play the script but in the meantime is there something up with media_player.play_media service or has this been deprecated? If the latter can we update the examples in the documentation?
My script looks like this:
front_door_camera_lounge:
alias: Front Door Camera Lounge
sequence:
- service: homeassistant.turn_on
entity_id: switch.0x000d6ffffe2b94dc_switch
- service: script.turn_on
entity_id: script.blr_lounge_amp_hector
- delay: '00:00:05'
- service: media_player.play_media
entity_id: media_player.kodi_main
media_content_type: DIRECTORY
media_content_id: special://profile/playlists/video/Cam_front_door.strm
And this is the error thrown in the log:
Logger: homeassistant.components.script
Source: components/kodi/media_player.py:759
Integration: Script (documentation, issues)
First occurred: 3:14:32 PM (1 occurrences)
Last logged: 3:14:32 PM
Front Door Camera Lounge: Error executing script. Unexpected error for call_service at pos 4: (-32602, 'Invalid params.', {'error': {'code': -32602, 'message': 'Invalid params.'}, 'id': 1963930333, 'jsonrpc': '2.0'})
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 154, in _async_step
self, f"_async_{cv.determine_script_action(self._action)}_step"
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 624, in _async_call_service_step
*self._prep_call_service_step(), blocking=True, context=self._context
File "/usr/src/homeassistant/homeassistant/core.py", line 1232, in async_call
await asyncio.shield(self._execute_service(handler, service_call))
File "/usr/src/homeassistant/homeassistant/core.py", line 1255, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
self._platforms.values(), func, call, required_features
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 412, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 600, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 443, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/kodi/media_player.py", line 237, in wrapper
await func(obj, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/kodi/media_player.py", line 759, in async_play_media
await self.server.Player.Open({"item": {"directory": str(media_id)}})
File "/usr/local/lib/python3.7/site-packages/jsonrpc_websocket/jsonrpc.py", line 45, in send_message
return message.parse_response(response)
File "/usr/local/lib/python3.7/site-packages/jsonrpc_base/jsonrpc.py", line 181, in parse_response
raise ProtocolError(code, message, data)
jsonrpc_base.jsonrpc.ProtocolError: (-32602, 'Invalid params.', {'error': {'code': -32602, 'message': 'Invalid params.'}, 'id': 1963930333, 'jsonrpc': '2.0'})
