Home Assistant Version: 0.45.1
Have this configuration in my configuration.yaml file a very basic samsungtv configuration:
media_player:
- platform: samsungtv
host: 10.0.0.58
Home Assistant with this configuration does not boot up successfully very often and when it does I recieve the following error:
The following components and platforms could not be set up:
media-player.samsungtv
Please check your config
I don’t understand where it is getting media-player instead of media_player, I have no other media_player includes at all. Was working perfectly fine a few days ago. home-assistant.log says this:
17-06-02 22:11:41 WARNING (MainThread) [homeassistant.setup] Setup of media_player is taking over 10 seconds.
17-06-02 22:11:42 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
17-06-02 22:11:42 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10 seconds.
When I take out the media_player section, Home Assistant boots up fine. hass --script check_config returns all green.
No idea what is wrong with it.
