Hi
I’m trying to use NodeRed to use Alexa TTS via media_player.alexa_tts as in the example below
I am not able to let it work with NodeRed.
I made an example below, but it does not work
Can someone help?
Hi
Can someone help?
Your example looks good other than in the function node the quotes around data
look off. I don’t know if you plan on changing the message
in the future or what not but in your current example you don’t really need the function node. You can just put all the information into the call-service node.
I used a function node because I would like to change either the media_player and the message, this was just a test.
I will try.
