Media_player source_list allways empty in the GUI
Hey guys,
I started converting the acer_projector switch into an acer_projector media player. The reason for me doing is it, that the media_player allows switching of sources, using:
@property
def source(self):
    return some_string
@property
def source_list(self):
    return some_list_of_strings
def select_source(self, source):
    msg = source_list[source]
    send_to_projector(msg)
I have also added SUPPORT_SELECT_SOURCE to the supported_features flag.
I know in genral my code works, because I can use the development tools to switch the input source of the projector service data as: {"entity_id" : "media_player.beamer", "source" : "HDMI"} and the source_list property returns a list of valid strings that can be parsed to the select_source function. However, the source_list in the GUI stays empty at all times. Any Idear why I see nothing there, even though the source_list property returns a constant list of strings.
For reference here is the current status of the component. Not super pretty but maybe it helps to find the issue.
Support for Projectors from Acer.
import logging
import re
import voluptuous as vol
from homeassistant.components.media_player import(
    SUPPORT_TURN_ON, SUPPORT_TURN_OFF, SUPPORT_SELECT_SOURCE, PLATFORM_SCHEMA,
    SUPPORT_VOLUME_STEP, SUPPORT_PLAY_MEDIA, SUPPORT_PLAY, MediaPlayerDevice,
from homeassistant.const import (
    STATE_ON, STATE_OFF, STATE_UNKNOWN, CONF_NAME, CONF_FILENAME,
    SERVICE_VOLUME_UP, SERVICE_VOLUME_DOWN)
import homeassistant.helpers.config_validation as cv
REQUIREMENTS = ['pyserial==3.1.1']
_LOGGER = logging.getLogger(__name__)
DEFAULT_NAME = 'Acer Projector'
DEFAULT_TIMEOUT = 1
DEFAULT_WRITE_TIMEOUT = 1
SUPPORT_ACER = SUPPORT_TURN_ON | SUPPORT_TURN_OFF | SUPPORT_SELECT_SOURCE |\
               SUPPORT_VOLUME_STEP | SUPPORT_PLAY_MEDIA | SUPPORT_PLAY
CONF_TIMEOUT = 'timeout'
CONF_WRITE_TIMEOUT = 'write_timeout'
ICON = 'mdi:projector'
QUERY_ECO_MODE = 'ECO Mode'
QUERY_INPUT_SOURCE = 'Input Source'
QUERY_LAMP = 'Lamp'
QUERY_LAMP_HOURS = 'Lamp Hours'
QUERY_MODEL = 'Model'
QUERY_DISPLAY_RESOLUTION = 'Display Resolution'
SET_ECO_MODE = 'Set ECO Mode'
SOURCE_ANALOGE_RGB = 'Analoge RGB'
SOURCE_DIGITAL_RGB = 'Digital RGB'
SOURCE_PBPR = 'PbPr'
SOURCE_SVIDEO = 'S-Video'
SOURCE_COMPOSITE_VIDEO = 'Composite Video'
SOURCE_COMPONENT_VIDEO = 'Component Video'
SOURCE_HDMI = 'HDMI'
# Commands known to the projector
CMD_DICT = {
    QUERY_LAMP: '* 0 Lamp ?\r',
    QUERY_LAMP_HOURS: '* 0 Lamp\r',
    QUERY_INPUT_SOURCE: '* 0 Src ?\r',
    QUERY_ECO_MODE: '* 0 IR 052\r',
    QUERY_MODEL: '* 0 IR 035\r',
    QUERY_DISPLAY_RESOLUTION: '* 0 IR 036\r',
    SET_ECO_MODE: '* 0 IR 051\r',
    SERVICE_VOLUME_UP: '* 0 IR 023\r',
    SERVICE_VOLUME_DOWN: '* 0 IR 024 \r',
    SOURCE_HDMI: '* 0 IR 050\r',
    SOURCE_ANALOGE_RGB: '* 0 IR 015\r',
    SOURCE_DIGITAL_RGB: '* 0 IR 016\r',
    SOURCE_PBPR: '* 0 IR 017\r',
    SOURCE_SVIDEO: '* 0 IR 018\r',
    SOURCE_COMPOSITE_VIDEO: '* 0 IR 019\r',
    SOURCE_COMPONENT_VIDEO: '* 0 IR 020\r',
    STATE_ON: '* 0 IR 001\r',
    STATE_OFF: '* 0 IR 002\r',
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
    vol.Required(CONF_FILENAME): cv.isdevice,
    vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
    vol.Optional(CONF_TIMEOUT, default=DEFAULT_TIMEOUT): cv.positive_int,
    vol.Optional(CONF_WRITE_TIMEOUT, default=DEFAULT_WRITE_TIMEOUT):
        cv.positive_int,
def setup_platform(hass, config, add_devices, discovery_info=None):
    """Connect with serial port and return Acer Projector."""
    serial_port = config.get(CONF_FILENAME)
    name = config.get(CONF_NAME)
    timeout = config.get(CONF_TIMEOUT)
    write_timeout = config.get(CONF_WRITE_TIMEOUT)
    add_devices([AcerSwitch(serial_port, name, timeout, write_timeout)])
class AcerSwitch(MediaPlayerDevice):
    """Represents an Acer Projector as Media Player."""
    def __init__(self, serial_port, name, timeout, write_timeout, **kwargs):
        """Init of the Acer projector."""
        import serial
        self.ser = serial.Serial(
            port=serial_port, timeout=timeout, write_timeout=write_timeout,
            **kwargs)
        self._serial_port = serial_port
        self._name = name
        self._state = False
        self._available = False
        self._state_attributes = {
            QUERY_LAMP_HOURS: STATE_UNKNOWN,
            QUERY_INPUT_SOURCE: STATE_UNKNOWN,
            QUERY_ECO_MODE: STATE_UNKNOWN,
            QUERY_MODEL: STATE_UNKNOWN,
            QUERY_DISPLAY_RESOLUTION: STATE_UNKNOWN,
        self._source_list = [
            SOURCE_ANALOGE_RGB, SOURCE_DIGITAL_RGB, SOURCE_PBPR, SOURCE_SVIDEO,
            SOURCE_COMPOSITE_VIDEO, SOURCE_COMPONENT_VIDEO, SOURCE_HDMI
        self._current_source = STATE_UNKNOWN,
        self.update()
    def _write_read(self, msg):
        """Write to the projector and read the return."""
        import serial
        ret = ""
        # Sometimes the projector won't answer for no reason or the projector
        # was disconnected during runtime.
        # This way the projector can be reconnected and will still work
        try:
            if not self.ser.is_open:
                self.ser.open()
            msg = msg.encode('utf-8')
            self.ser.write(msg)
            # Size is an experience value there is no real limit.
            # AFAIK there is no limit and no end character so we will usually
            # need to wait for timeout
            ret = self.ser.read_until(size=20)
            ret = ret.decode('utf-8', 'ignore')
        except serial.SerialException:
            _LOGGER.error('Problem comunicating with {}'.format(self._serial_port))
        self.ser.close()
        return ret
    def _write_read_format(self, msg):
        """Write msg, obtain awnser and format output."""
        # awnsers are formated as ***\rawnser\r***
        awns = self._write_read(msg)
        match = re.search(r'\r(.+)\r', awns)
        if match:
            return match.group(1)
        return STATE_UNKNOWN
    @property
    def available(self):
        """Return if projector is available."""
        return self._available
    @property
    def name(self):
        """Return name of the projector."""
        return self._name
    @property
    def is_on(self):
        """Return true if the projector is turned on."""
        return self._state
    @property
    def state(self):
        """Return state."""
        if self._state:
            return STATE_ON
        return STATE_OFF
    @property
    def state_attributes(self):
        """Return state attributes."""
        return self._state_attributes
    @property
    def supported_features(self):
        """Flag media player features that are supported."""
        return SUPPORT_ACER
    @property
        """Return list of input sources"""
        return self._source_list
    @property
    def source(self):
        """Name of the current source"""
        current_source = self._state_attributes.get(QUERY_INPUT_SOURCE)
        if "Src 0" in current_source or "Src 8" in current_source:
            current_source = SOURCE_HDMI
        return current_source
    def update(self):
        """Get the latest state from the projector."""
        msg = CMD_DICT[QUERY_LAMP]
        if 'Lamp 1' in awns:
            self._state = True
            self._available = True
        elif 'Lamp 0' in awns:
            self._state = False
        else:
        for key in self._state_attributes:
            msg = CMD_DICT.get(key, None)
            if msg:
                awns = self._write_read_format(msg)
                self._state_attributes[key] = awns
    def turn_on(self):
        """Turn the projector on."""
        msg = CMD_DICT[STATE_ON]
        self._state = STATE_ON
    def turn_off(self):
        """Turn the projector off."""
        msg = CMD_DICT[STATE_OFF]
        self._state = STATE_OFF
    def volume_up(self):
        """Volume up"""
        msg = CMD_DICT[SERVICE_VOLUME_UP]
    def volume_down(self):
        """Volume down"""
        msg = CMD_DICT[SERVICE_VOLUME_DOWN]
        """Select input source."""
        msg = CMD_DICT.get(source, '')
    def media_play(self):
    def media_pause(self):
    def play_media(self, media_type, media_id, **kwargs):
        pass
