Media player stopped playing mp3
A few weeks ago I have setup a media player via esphome. It was working. I was able to play tts and mp3 files. A few days ago, when tried to play mp3 files, there are no audio coming from the speaker. The stange thing is that I am still able to create tts text message. The text audio outputs through the speaker. Mp3 files will not. Logs does not show any errors. I think one of the esphome updates has broken it. I would like to go back to a specific esphome only for this device config setup and not everyone of my devices. Is this possible? I am stuck at this point of how to troubleshoot.
Log when playing an mp3 files
http://192.168.1.20:8123/media/local/music/Sarah%20Mclachlan%20-%20When%20She%20Loved%20Me.mp3?authSig=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJpc3MiOiI3NjAyMWU5Njg3ZDQ0OWYzOTAwYjE2MmM1NGIyNTgwYyIsInBhdGgiOiIvbWVkaWEvbG9jYWwvbXVzaWMvU2FyYWggTWNsYWNobGFuIC0gV2hlbiBTaGUgTG92ZWQgTWUubXAzIiwicGFyYW1zIjp7fSwiaWF0IjoxNjc1NTY5MTkzLCJleHAiOjE2NzU2NTU1OTN9.mfltQFoy-O5_bgw5-LxirlTkC4dkA_ZNFd6vklxhmVk
This is the url that is outputted in the log above. When I run this in a browser, it works.
Log when playing tts
config
# ESP32 NodeMCU
substitutions:
  platform: ESP32
  board: nodemcu-32s
esphome:
  platform: $platform
  board: $board
wifi:
  ssid: !secret ssid3
  password: !secret ssid_pass
  manual_ip:
    static_ip: 192.168.1.113
    subnet: 255.255.255.0
    gateway: 192.168.1.1
captive_portal:
logger:
api:
  encryption:
    key: !secret esphome_apikey
ota:
  password: !secret ota_pass
media_player:
  - platform: i2s_audio
    dac_type: external
    i2s_lrclk_pin: GPIO25
    i2s_dout_pin: GPIO22
    i2s_bclk_pin: GPIO26
    mode: stereo
    on_play:
      - logger.log: "Playback started!"
    on_pause:
      - logger.log: "Playback paused!"
    on_idle:
      - logger.log: "Playback finished!"
  - platform: wifi_signal
    name: $name wifi signal
    update_interval: 15s
    filters:
      - sliding_window_moving_average:
          window_size: 15
          send_every: 15
          send_first_at: 1
binary_sensor:
  - platform: status
switch:
  - platform: restart
    icon: mdi:restart
There is an old saying in computing: “if it isn’t broken, don’t fix it!”
Can you recall what version of esphome did you compile it with when it worked?
Not really. I normally just update the esphome via HA, but I don’t compile for each of the devices at the same time. Looking at the previous esphome version there was a fix for the i2s_audio on 2022.12.1. I am assume I had it working on 2022.12.0. I am currently compiled on 2022.12.8.
