I want to create a script to turn on my receiver and select input Pandora. I've gotten this far but How/Where do I put the line for Pandora? Note: this is for a Yamaha Receiver and the page does say "Other functions such as source select are in progress of being developed." but in the available services within home assistant there is a select source option. When/If it ever works I would still like to know how the script would work.
sequence:
- service: media_player.turn_on
entity_id: media_player.receiver
- delay:
seconds: 5
- service: media_player.select_source
entity_id: entity_id: media_player.receiver
I just got this to work with an automation, should be the same I think. Devices are a raspberry pi squeezeplayer (hoolio) and a Yamaha AV-Receiver RX-V479 (kitchen_avr)
From the action part at the end of my automation you should be able use this:-
## note - hoolio is the name of my squuezebox media player
alias: Hoolio begins playing
- platform: state
entity_id: media_player.hoolio
to: 'playing'
- platform: state
to: 'playing'
#change this to match your AVR
entity_id: media_player.kitchen_avr
source: AV4
“media_player.kitchen_avr” is the name of my receiver in HASS - the input on the reciever for my squeezeplayer named hoolio is “AV4” - the source. in data:
I can’t thank you enough BarryHampants, worked great!
You wouldn’t believe how much it pleases me to know I have finally helped someone else here instead of my usual leaching!
I should mention I also have the reverse of this set up in another automation - to turn the AVR off when playback has finished. No input source needed for switching off though.
Hi, I am still learning automation. FOr now I want just to press a switch/button and turn on AVR and put in the correct output.
How would I do that?
This below and then what?
source: AV4
An automation needs at minimum a trigger and an action. You have the action so now you need a way to trigger it.
What is your switch/button device?
alias: claudio presses the button
- platform: state
entity_id: button.claudio_button
to: 'on'
source: HDMI1
I made a script with a sequence.
I am a newb, and have a long learning curve. Not yet there for triggers and automation
I saw your script, if you can do that you will find automations even easier. Automation is the basis of Home Automation.
Have a read. There are only two necessary parts to an automation, a trigger and an action.
Do you have a button device or switch?
What triggers your script?
You can make an automation now with the action.
- service: script.its_time_for_lunch
a click on the front-end. I got a amazon dash to test, nothing else as real switch though. I ordered some stuff (PIR sensors) but I don’t have them yet.
Ahh I have presence detection but its crap IMO, tried owntracks, gpslogger, netgear, all don’t work well. Very unreliable.
Trying to use ibeacon/bluetooth technology, but I am not there yet.
p.s. maybe with the new GPS Galileo system will work better, in Europe.
Ah - OK I misunderstood what you meant by button or switch.
I have the same problem with presence. For now I use an input boolean to prevent my welcome home routine running 10 times a night rather than just on the initial connection. I have given up on GPS.
I think the best is using bluetooth: the question is what to get as transmitter and receiver (and which to put ON you/perons of the family)
Have a similar problem.
I have a script up and running, turning my mediacenter with all components on, incl. correct source, etc.
My plan is to switch it on and of via webui and echo dot for now.
As for the script I just have an activate button.
For the first instance the eco dot that switches a emulated hue needs an on and off switch.
Perfect would be a activate button with if case bolean that switches between on and off for the web interface and a hidden on off switch for the echo dot
I did see this post yesterday that may be what you are looking for?
Yeah thanks. Thats exactly what I wanted to do, but unfortunately it doesnt work for me. I get no errors and the switches/scripts are working but nothing happens when I change the bolean.
My working sllution is an automation:
input_boolean:
watch_movie:
initial: off
script:
mediacenter_on:
alias: mediacenter on
sequence:
entity_id:
- media_player.avr_wohnzimmer
- service: switch.turn_on
entity_id:
- switch.htpc
entity_id: media_player.avr_wohnzimmer
source: HTPC
mediacenter_off:
alias: mediacenter off
sequence:
- service: media_player.turn_off
entity_id:
entity_id:
- media_player.kodi
automation:
- alias: Start Makro Mediacenter
platform: state
entity_id: input_boolean.watch_movie
to: 'on'
service: script.turn_on
entity_id: script.mediacenter_on
- alias: Off Makro Mediacenter
platform: state
to: 'off'
entity_id: script.mediacenter_off
So just starting out myself, and i have found that a good restart of HASS works better than a reload/restart in the GUI.
Also spotted that in your script u have put you entity_id on a new line and stuck a - in front, but only on some of them.
I corrected how i think it should be.
script: mediacenter_on: alias: mediacenter on sequence: - service: media_player.turn_on entity_id: - media_player.avr_wohnzimmer - service: switch.turn_on entity_id: - switch.htpc - service: media_player.select_source data: entity_id: media_player.avr_wohnzimmer source: HTPC
mediacenter_off: alias: mediacenter off sequence: - service: media_player.turn_off entity_id: - media_player.avr_wohnzimmer - service: media_player.turn_off entity_id: - media_player.kodi
I hope this helps as i’ve just spent an age looking at whether i needed to - my
Hmmm that might still not be copy and pasta ready, but if u look i’ve not got the entity_id on a new line
I need some help… I want to make a script which checks if both TVs are off, if yes it turns on one of them and then check which one is open and changes the source. I have the code below. If I uncomment the commented part of the script it works only when both TVs are off. If one of them is turned on it gives me this error. Any ideas? The code is below
Entity ID is an invalid entity id for dictionary value @ data[‘entity_id’]
netflix:
alias: Netflix Script
sequence:
# - service: media_player.turn_on
# data_template:
# entity_id: >-
# {% if (states('media_player.bedroom_tv') == 'off') and (states('media_player.living_room_tv') == 'off') %}
# media_player.living_room_tv
# {% endif %}
data_template:
entity_id: >
{% if (states('media_player.bedroom_tv') == 'on') %}
{% elif (states('media_player.living_room_tv') == 'on') %}
{% endif %}
source: Netflix```
Hi. You have if and elif but no else.
If both ifs are false there’s no default and so no entity_id that’s valid.
Test it in your template dev tool.
Yes but I don’t think that this is the case… What I mean, if I have both TVs off and run the script (with the commented part) the TV turns on and then it changes the source… If i run the script second time with one of the TVs already on is when i get the error. I will try what you are saying when i will be at home and i will tell you the results.
Do you know if/how i can put the commented part to run in the “else” statement? So first it will check if any of the TVs are open and then turn on one
