Media Player Turn on to Television Channels
So I am trying to use a scene or script so that if I am away at night the television will turn on randomly; however I am struggling a bit to figure this out. I am using Occusim and it is setup and works fine. The problem I am having is setting up a scene or script to turn the tv to channels rather than the last input that was used. For example if I was last watching HDMI 4 (AppleTV) then when I use the scene to turn on the tv it will default to HDMI 4. I want to have it turn on and switch to a tv channel so that the tv doesn’t sit idle on the apple tv screen for hours which would give it away that no one was home. Is this possible to do? I have a Sony Bravia TV. The only inputs that I seem to be able to select from are HDMI 1 through HDMI 4. There doesn’t seem to be a Channels option. Any help would be appreciated.
Does anyone have any ideas on this?
