Hello everyone, my notifications through Alexa have stopped due to an error which arise when I try to set the media player volume (" Failed to perform the action media_player.volume_set. Unknown error"). Actually, the volume changes but the automation stops in that point.
Any lead?
Hi, thanks for your answer.
This is a script that I call within an automation, which stops everytime the above reported script is run.
I’ve tried to debug it in Developer tool, and the device_id is a must. Cannot run the script without indicate in which device (or entity) the function volume_set have to be applied.
Amazing… I did try keeping only the entity_id line but the result is the same, even if the volume level changes I’ve got the error: " Failed to perform the action media_player.volume_set. Unknown error"
Thank you for the lead, it seems volume set action works … but now Alexa media player integration crashes. I delete it and tried to re-install it but always get “Failed to log-in”
SOLVED: I had to erase the file alexa_mediaxxxxx.pickle
