I have my denon ARV set up as a media player but I would like to display the volume controls and source options on a card, without having to click on the media player control to get to this menu:
Is that possible? How to go about it?
Hereās what I have for Denon volume slider on my Denon S720W. If you have a different model it might need some changes, but you could try this. It updates both ways so the volume slider should stay in sync even if you change from a TV remote etcā¦
input_number:
denon_volume:
icon: mdi:volume-medium
initial: 30
min: 1
max: 100
step: 1
sensors:
denon_volume:
value_template: >
{% if is_state('media_player.denon_avr_s720w', 'on') %}
{{ (state_attr('media_player.denon_avr_s720w', 'volume_level') * 100) | int }}
{% endif %}
friendly_name: Receiver Volume Level
icon_template: mdi:volume-medium
automation:
- alias: "Denon Set Volume"
initial_state: 'on'
platform: state
entity_id: input_number.denon_volume
- service: media_player.volume_set
data_template:
entity_id: media_player.denon_avr_s720w
volume_level: >
{{states('input_number.denon_volume') | int / 100}}
- alias: "Denon Update Volume Slider"
initial_state: 'on'
- platform: state
entity_id: sensor.denon_volume
- platform: homeassistant
event: start
condition:
condition: state
entity_id: media_player.denon_avr_s720w # receiver must be on to set the volume, without this would throw error on startup
state: 'on'
- delay:
seconds: 3
- service: input_number.set_value
data_template:
value: '{{ trigger.to_state.state }}'
(This gives you a slider only, not the mute button etc). Display in your Lovelace with the input_number.denon_volume entity.
I will give that a shot later, thanks.
Is it possible to do the sources the same way?
The mini media player card has access to both source and volume in the card.
EDIT: here https://github.com/kalkih/mini-media-player and installable with HACS.
That looks exactly like what I need.
Iām new enough to HA/yaml and as I understand it when referencing the ui-lovelace.yaml file, it means the UI edit of HA is no longer possible and all changes need to be directly into the ui-lovelace.yaml file?
newbie here - can you tell me what yaml file(s) the code goes into?
Look at the top of the page. Click āDocsā. Read.
This type of comment is why alot of people dont like asking for help as you come back with comments like you, you might understand this well but other dont
What so youād rather I copy and paste the docs in here?
Yea like to the document would have been nice,something like, this type of info can be found in the document area, here is a link to it ālinkā i hope it help. Basicly the same thing but read a lot better
Hey Sean, with your slider code, how does the āinitialā for the input_number work? So what I get on a fresh restart is it shows 30 and the slider is real low. If I move my harmony remote up and down a bit it then adjusts to the current volume level that the remote is at. So my remote may be at a level of 60 when HA restarts but sits at 30 until itās changed or moved unless it would have eventually adjusted on itās own.
I would suggest just removing that initial: 30 line.
Itās not needed and in hindsight just complicated things. The idea of it was to make my receiver always have an initial volume level of 30, but it didnāt work how I wanted and I never cared enough to look into fixing it.
By deleting that āinitialā line it will just remember your last volume level upon restart. So if itās at volume 60 on your remote/receiver, the input_number in Home Assistant should also remain at 60 even after a restart. That is probably the behavior you and most people want.
Thanks Iāll do that. Iām having a visual problem with the slider:
So it works good but for the above, when on mobile, the 63 is cut off. If I turn the screen landscape it is there but cutting it off for some reason on portrait. Assuming itās cut off and not a view change based on where and how itās being viewed. So like the right side is cut off.
EDIT: Also I am getting an error in the logs:
2020-03-17 19:25:14 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'dict object' has no attribute 'to_state'
Thinking itās from this part of the automation?
Good catch on that visual issue, I believe that might be a bug in the frontend and just opened an issue for it here: https://github.com/home-assistant/frontend/issues/5266
Not sure on the template part, hopefully someone else can help you with that.
For the input number can you not set negative values? Like on my Denon itās basically -79dB to 18.5db. I get errors like:
Error while executing automation automation.denon_set_volume. Invalid data for call_service at pos 1: value must be at least 0 for dictionary value @ data[āvolume_levelā]
So then technically the volume on the slider doesnāt match whatās on the TV.
@nickrout Iāve tried installing the resource for the mini media player. Did as the documentation says but when checking the config it gives me an error that it canāt find the resource. I do have the file in my www folder. I also tried doing it through the resources tab and still not getting it to show up in the UI when adding a new card. What am I doing wrong?
Better to ask in the main thread for the card.
Still getting this in the logs. Thought Iād see if anyone knows as trying to clean up the logs. Imagine the error means itās not doing anything but not sure.
