Media Player with more information
Hello
I was wondering if there is a way to setup Media PLayer from google or Alexa to show what song is playing. This information is available in parameters but I can`t get it on the screen under the name of the device.
any idea?
Cap2222111ture
Have a look at the mini media player card.
I apologies, but I`m still using configuration.yaml and I do not have ui.lovelace.yaml.
On ui.lovelace.yaml I was not able to use “Configure UI”.
Since I do not use/have ui/lovelace.yaml I can not install this plugin
any advice?
Honestly, and this is not meant to be condescending in any way, your best bet is diving in and moving to lovelace. Most here have done it, and like anything, there’s a learning curve, but it’s worth it.
There are numerous YouTube videos that I used to help get mine off the ground, and then Google + these forums are invaluable tools to get you where you need to go.
You won’t regret it.
Yes you can, see this guide.
Thank you Sir, it fixed my problem!
