Media Players optimizing script
The below code works but is there a way that this code can be optimized?
The script triggers if tv or tv_1 is in state (playing, paused, idle or unavailable). Only one of the tv will be playing at a given time.
Once the script is triggered,
  1. It checks if tv or tv_1 is playing then it turns OFF the lights and sets input_boolean.movie_mode to “off” (its required for TTS in another script) and call the script to turn OFF the lights.
  2. It checks if tv or tv_1 is paused, idle or unavailable then it turns ON the lights and sets input_boolean.movie_mode to “on” (its required for TTS in another script) and call the script to turn ON the lights.
alias: Movie
description: ""
  - platform: state
    entity_id:
      - media_player.tv
      - media_player.tv_1
    to:
      - playing
      - paused
      - idle
      - unavailable
condition: []
  - choose:
      - conditions:
          - condition: and
            conditions:
              - condition: or
                conditions:
                  - condition: state
                    entity_id: media_player.tv
                    state: playing
                  - condition: state
                    entity_id: media_player.tv_1
                    state: playing
              - condition: state
                entity_id: input_boolean.movie_mode
                state: "off"
        sequence:
          - service: script.turn_lights_on_off
              flag: true
      - conditions:
          - condition: and
            conditions:
              - condition: or
                conditions:
                  - condition: state
                    state:
                      - paused
                      - idle
                      - unavailable
                  - condition: state
                    state:
                      - paused
                      - idle
                      - unavailable
              - condition: state
                state: "on"
                enabled: true
        sequence:
              flag: false
    default: []
mode: single
  - platform: state
    entity_id:
      - media_player.tv
      - media_player.tv_1
    to:
      - playing
      - paused
      - idle
      - unavailable
a. Can this part be converted to a template which returns the entity_id of the tv that is playing ?
            conditions:
              - condition: or
                conditions:
                  - condition: state
                    state: playing
                  - condition: state
                    state: playing
b. Can this part be converted to template which return the entity_id of the tv that is playing ?
C. Can the code be optimized?
It will anyway. Whichever entity triggers the automation will be available in the variable
{{ trigger.entity_id }}.
Yes using a template condition:
            conditions:
              - condition: template
                value_template: "{{ is_state(trigger.entity_id, 'playing') }}"
Here’s one way, separate your triggers and give them ids:
  - id: playing
    platform: state
    entity_id:
      - media_player.tv
      - media_player.tv_1
    to:
      - playing
  - id: other_state
    platform: state
    entity_id:
      - media_player.tv
      - media_player.tv_1
    to:
      - paused
      - idle
      - unavailable
Then all of this:
      - conditions:
          - condition: and
            conditions:
              - condition: or
                conditions:
                  - condition: state
                    state:
                      - paused
                      - idle
                      - unavailable
                  - condition: state
                    state:
                      - paused
                      - idle
                      - unavailable
Can be changed to:
      - conditions:
          - condition: trigger
And all of this:
      - conditions:
          - condition: and
            conditions:
              - condition: or
                conditions:
                  - condition: state
                    state: playing
                  - condition: state
                    state: playing
              - condition: state
                state: "off"
Can be changed to:
      - conditions:
Thank you​:+1::+1:
