I am having no luck with this. It says it cant find the media player component.
Last login: Sat May 28 15:52:56 on ttys000
Mac-mini:~ hadley$ hass --open-ui
Config directory: /Users/hadley/.homeassistant
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=homeassistant>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=homeassistant>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=toggle, domain=homeassistant>
INFO:homeassistant.bootstrap:Home Assistant core initialized
INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
INFO:homeassistant.loader:Loaded http from homeassistant.components.http
INFO:homeassistant.loader:Loaded history from homeassistant.components.history
INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
INFO:homeassistant.loader:Loaded api from homeassistant.components.api
INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
ERROR:homeassistant.loader:Unable to find component mediaplayer
INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
INFO:homeassistant.loader:Loaded introduction from homeassistant.components.introduction
INFO:homeassistant.components.introduction:
Hello, and welcome to Home Assistant!
We'll hope that we can make all your dreams come true.
Here are some resources to get started:
- Configuring Home Assistant:
https://home-assistant.io/getting-started/configuration/
- Available components:
https://home-assistant.io/components/
- Troubleshooting your configuration:
https://home-assistant.io/getting-started/troubleshooting-configuration/
- Getting help:
https://home-assistant.io/help/
This message is generated by the introduction component. You can
disable it in configuration.yaml.
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=introduction>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=log, domain=logbook>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; friendly_name=Sun, next_setting=2016-05-29T02:48:04+00:00, next_rising=2016-05-29T11:59:57+00:00, elevation=53.16 @ 2016-05-28T15:54:35.404287-06:00>, entity_id=sun.sun, old_state=None>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
INFO:homeassistant.loader:Loaded sensor.yr from homeassistant.components.sensor.yr
INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): api.yr.no
INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): api.met.no
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sensor.yr_symbol=2; about=Weather forecast from yr.no, delivered by the Norwegian Meteorological Institute and the NRK, friendly_name=yr Symbol, entity_picture=//api.met.no/weatherapi/weathericon/1.1/?symbol=2;content_type=image/png @ 2016-05-28T15:54:36.294755-06:00>, entity_id=sensor.yr_symbol, old_state=None>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=process, domain=conversation>
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
INFO:homeassistant.util.package:Attempting install of netdisco==0.6.7
Command “/Library/Frameworks/Python.framework/Versions/3.5/bin/python3.5 -c “import setuptools, tokenize;file=’/private/var/folders/17/t90frj_91mv090jqdg2kcr840000gn/T/pip-build-xuwgleh2/netifaces/setup.py’;exec(compile(getattr(tokenize, ‘open’, open)(file).read().replace(’\r\n’, ‘\n’), file, ‘exec’))” install --record /var/folders/17/t90frj_91mv090jqdg2kcr840000gn/T/pip-i7avt79k-record/install-record.txt --single-version-externally-managed --compile --home=/var/folders/17/t90frj_91mv090jqdg2kcr840000gn/T/tmpdmzncabv” failed with error code 1 in /private/var/folders/17/t90frj_91mv090jqdg2kcr840000gn/T/pip-build-xuwgleh2/netifaces
ERROR:homeassistant.bootstrap:Not initializing discovery because could not install dependency netdisco==0.6.7
Starting Home-Assistant
INFO:homeassistant.core:Starting Home Assistant (13 threads)
INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=restart, domain=homeassistant>
INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
INFO:homeassistant.core:Timer:starting
INFO:homeassistant.components.http:“GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1” 200 -
INFO:homeassistant.components.http:“GET /api/bootstrap HTTP/1.1” 200 -
INFO:homeassistant.components.http:“GET / HTTP/1.1” 200 -
INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=above_horizon; friendly_name=Sun, next_setting=2016-05-29T02:48:04+00:00, next_rising=2016-05-29T11:59:57+00:00, elevation=53.0 @ 2016-05-28T15:54:35.404287-06:00>, entity_id=sun.sun, old_state=<state sun.sun=above_horizon; friendly_name=Sun, next_setting=2016-05-29T02:48:04+00:00, next_rising=2016-05-29T11:59:57+00:00, elevation=53.16 @ 2016-05-28T15:54:35.404287-06:00>>
INFO:homeassistant.components.api:Found broken event stream to 192.168.86.126, cleaning up
