If i play a single media file from the media tab in home assistant, it will play the file then stop playback. If I then play a second file after the first one, it will play the newly enqueued file, then play the first file.
I also am of the opinion that this behavior is causing indefinite looping when sending tracks to the same media player via music assistant.
I have been beating my head against the wall trying to figure this one out. I am not sure what logs may be relevant, at a glance I see nothing amiss.
Repeat mode is also off in the GUI in home assistant
running the action action: media_player.clear_playlist
data: {}
device_id: dcda6452bcc663d0552ab4d9dc8f2eef
results in a green checkmark, but i can immediately go back over to the media player control and hit “play” and it will resume playing audio. Should that action not have cleared the playlist? Why is there still a track loaded on the media player seemingly no matter what I do?
items sent via music assistant to the entity media_player.master_bedroom_audio_3 loop forever until I manually stop playback. Ill create a new thread for that ty
