From a few days, after some updates, the paused status seems to have disappeared: after pausing any media player instance, the relative device goes to paused status, but both the user interface and the recovered status, for example, from the development tools is still playing.
Do you have the same behavior? any ideas?
Thanks!
Welcome @lorenzo1773,
I have Sonos players and don’t recognize what you are writing. I think people will be better capable of helping you if you share which media players you have that show the described issue.
I have Kodi, Panasonic and Yamaha media players and am not seeing this behaviour on either.
Which media player integration are you using?
Thanks for the replies.
I have Alexa and SkyQ media players.
My first impression was that the problem was there on both of them. After your answers I tested more carefully and found that the problem was only with SkyQ media player.
I tried to install the previous version and everything works fine.
So the problem is present in v2.7.14 and not in v2.6.10 of SkyQ integration.
Do you still have this problem with SkyQ?
No, the problem was fixed some versions ago.
Today I installed v8.2.6 and I confirm that the problem is not present.
I thought I reported that the problem has been fixed, but I don’t see the message … sorry!
Thanks!
Just wanted to check, because I made a change to differentiate apps (e.g. Netflix) from Sky Q channels in v2.8.6. Netflix doesn’t understand ‘Pause’ whilst Sky Q does. For Netflix, you have to send ‘Play’ for both pause and play.
