Mediola2mqtt: Simple Mediola to MQTT bridge with HA support
Hey @andyboeh I recently purchased the Mediola Gateway on the cheap on eBay, waiting for the delivery now. But I’d love to know more what was your alternative solution that you went with?
I changed quite a bit since the initial setup of my Mediola:
  • Elero blinds are now controlled using esphome-elero
  • Somfy blinds are now controlled using ESPSomfy-RTS
  • The single Intertechno switch that I had has been replaced by a Homematic switch as I moved the thermostats from MAX! to Homematic anyway
Sounds interesting, what hardware did you use for the 868 Mhz solution?
ESP32 (WT32-ETH01 as I have it connected via Ethernet) and TI CC1101 RF module (“rescued” from an old smart home central that is no longer supported by the manufacturer).
Thanks! I was looking for something to control my Elero blinds. Also, in the meantime I found your website :slight_smile: The part with copying the values from the pilot looks slightly challenging :slight_smile:
Also, I noted that tilting is done by sending just one command? Yet you can tilt the blinds two way?
I do not have any blinds that support tilt, so this was implemented with a user. There is one issue open at github that deals with thtat: Example config.yaml · Issue #1 · andyboeh/esphome-elero · GitHub
It really isn’t. You just look at the log and figure out the values.
I finally got my hands on the eBay Mediola gateway. Unfortunately it doesn’t work properly (I’m unable to add any of my Elero devices for weird reason “unable to enter pairing mode”) so I’m ditching the idea.
Started looking into your solution with ESP/CC1101. I read that you caniballised the chip from another device. Do you think that the cheap CC1101 modules from AliExpress will work? Or is it a waste of time?
Which Gateway version did you get?
I once bought a used gateway v4 where no Elero ID was set. You can check by running the following command in your browser:
http://mediola.lan/command?XC_FNC=GetSI
This returns a lot of status codes, check if there is a value set for “EID”. If not, you can manually set one - I forgot where I learned that from but it wasn’t easy to find:
http://mediola.lan/command?XC_FNC=rfchipcmd&type=setERAdr&adr=aabbcc
aabbcc is your Elero ID in hex. You can pick any number, they should not collide with your blinds.
That said: Sure, any CC1101 module will work if it isn’t broken. You might have to experiment and/or measure the correct frequency settings (they are configurable). You can use a cheap RTL433-based SDR for that. I’ve used these modules in the past for various Homematic projects (but they needed frequency calibration).
The gateway is a v5, so not officially supported by your solution :slight_smile: But I’ll give it a try, thanks!
I’m ordering a CC1101 from Ali anyway, we’ll see what it can do.
Nope, that didn’t work :confused: the EID was set, I changed it to my my own string, but that didn’t work either. Here’s the full dump from the first command you mentioned above:
{XC_SUC}{“HWV”:“E1”,“HWRV”:“01”,“FWV”:“1.0.31”,“BUILD”:“0007”,“TZ”:“21”,“TIME”:“20:13:53 18.3.2024”,“LONG”:“00D2”,“LAT”:“020A”,“RFM”:“1601”,“RFCAL”:“170C”,“PIN”:“XXXX”,“EID”:“031337”,“RGB”:“03”,“DC”:“0000/88B8”,“ststart”:“20:05:25 18.3.2024”,“HM”:{“ADR”:“343939”,“KEY”:“FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF”}}
Hello, can someone help me with the installation? I have HomeAssistant in a VM on a Windows PC. So I tried to run mediola2mqtt directly on the windows pc. But when I start it with the CMD I got the following error:
Running in local mode
Exception ignored in: <function Client.__del__ at 0x000001F36E1656C0>
  File "C:\Python312\Lib\site-packages\paho\mqtt\client.py", line 874, in __del__
    self._reset_sockets()
  File "C:\Python312\Lib\site-packages\paho\mqtt\client.py", line 1133, in _reset_sockets
    self._sock_close()
  File "C:\Python312\Lib\site-packages\paho\mqtt\client.py", line 1119, in _sock_close
    if not self._sock:
AttributeError: 'Client' object has no attribute '_sock'
  File "<frozen runpy>", line 198, in _run_module_as_main
  File "<frozen runpy>", line 88, in _run_code
  File "C:\mediola2mqtt\mediola2mqtt.py", line 309, in <module>
    mqttc = mqtt.Client()
TypeError: Client.__init__() missing 1 required positional argument: 'callback_api_version'
  1. Windows is completely untested, you are on your own.
  2. Paho-MQTT 2.0.0 seems to have introduced a backwards-incompatible API change. Use one of the 1.x.x releases or fix the error message - read client module — Eclipse paho-mqtt documentation
Hi Andyboeh, thanks for the quick reply. It works with Paho-MQTT 1.6.1.
@andyboeh It works and I can send the opening or close command from HA to the Elero blind. But after the command was send the Python Script in Windows close automaticly. Before I can send the next command I have to start it again in Windows CMD with “python mediola2mqtt.py” and then I can send the next command from HA. Do you have an idea how I can get mediola2mqtt run on windows endless?
When it closes, there is probably an error message. Capture that and fix it.
Hi, you are right it closes with KeyError: ‘buttons’
I deleted the buttons section because I don’t have any buttons which I want to have in the yaml.
But this seems not possible. Do I have to configure at least one button?
IIRC, you need the section buttons:, but it can be empty. Or you fix the python code, could be a bug, IDK.
Thank you for the quick response. I will try to find a Solution. For the moment it works if I copy one “button” from the example.yaml to my .yaml That fine for me so far.
Its great to have your support even when you already archived this project. Many thanks.
tried to install this in Home Assistant, got this error!
Add-on konnte nicht installiert werden
The command ‘/bin/ash -o pipefail -c pip3 install paho-mqtt’ returned a nonzero code: 1
any solution for this?
If you found the correct post via the search function, it would save all others quite some time by linking it: Trying to add a mediola2mqtt add-on fails - #5 by jeutie
