Medion MD 18500
I’ve got a Medion MD 18500 robotvacuum and I’ve installed an ESP-M3 to smarten the device. Ksya has done some great work on a similar device, the ILife V5s. I’ve connected the ESP-M3 without battery and docking. The three LEDs work and I can also read the IR-sensors. I had to add a pull-up because otherwise the logging of the IR-readings would be full of garbage data. So I can read the data, in pronto and raw. Whenever I try to send IR data from the ESP-M3, with and without pull-up, to the MD 18500 it doesn’t respond. I’ve also tried the RAW-codes from KSYA, but these didn’t work. Any idea’s on where it/I went wrong?
RAW IR-Data (the bigger data is the reading of the UP-key on the remote):
[20:57:59][I][remote.raw:041]: Received Raw:
[20:58:00][I][remote.raw:041]: Received Raw:
[20:58:01][I][remote.raw:041]: Received Raw:
[20:58:02][I][remote.raw:041]: Received Raw:
[20:58:02][I][remote.raw:041]: Received Raw: 150
[20:58:02][I][remote.raw:041]: Received Raw: -949
[20:58:02][I][remote.raw:041]: Received Raw: 3313
[20:58:03][I][remote.raw:041]: Received Raw:
[20:58:03][I][remote.raw:041]: Received Raw: 64
[20:58:03][I][remote.raw:041]: Received Raw: 65, -4756
[20:58:03][I][remote.raw:041]: Received Raw: 6389
[20:58:10][I][remote.raw:041]: Received Raw:
[20:58:13][I][remote.raw:041]: Received Raw:
[20:58:13][I][remote.raw:028]: Received Raw: -4500, 534, -587, 537, -584, 537, -561, 561, -562, 533, -588, 539, -585, 539, -1706, 541, -557, 562, -1681, 540, -583, 537, -1685, 561, -563, 559, -1684, 534, -588, 512, -1710, 560, -560, 563, -560, 535, -1712, 537, -586, 537, -1682, 560,
[20:58:13][I][remote.raw:041]:   -564, 536, -1714, 532, -587, 540, -1682, 559, -1686, 537, -586, 537, -1708, 539, -559, 561, -1683, 540, -585, 536, -1683, 564, -558, 561
[20:58:15][I][remote.raw:041]: Received Raw:
[20:58:17][I][remote.raw:041]: Received Raw:
[20:58:19][I][remote.raw:041]: Received Raw:
[20:58:19][I][remote.raw:028]: Received Raw: -4506, 537, -585, 537, -565, 557, -562, 562, -560, 534, -590, 535, -588, 536, -1685, 562, -560, 562, -1683, 539, -586, 535, -1710, 538, -561, 557, -1687, 541, -583, 537, -1709, 537, -561, 537, -586, 512, -1736, 536, -587, 536, -1686, 561,
[20:58:19][I][remote.raw:041]:   -560, 513, -1737, 536, -586, 537, -1685, 561, -1685, 539, -585, 538, -1684, 564, -558, 536, -1712, 541, -582, 538, -1682, 563, -562, 534
[20:58:21][I][remote.raw:041]: Received Raw:
[20:58:21][I][remote.raw:028]: Received Raw: -4500, 536, -610, 513, -585, 537, -561, 559, -561, 535, -588, 537, -585, 535, -1689, 558, -556, 562, -1684, 537, -584, 512, -1711, 559, -559, 535, -1710, 537, -582, 538, -1682, 561, -558, 562, -559, 539, -1735, 510, -583, 539, -1682, 559,
[20:58:21][I][remote.raw:041]:   -564, 533, -1709, 536, -587, 536, -1683, 535, -1710, 534, -589, 536, -1683, 560, -561, 564, -1682, 536, -585, 536, -1683, 564, -560, 561
[20:58:22][I][remote.raw:041]: Received Raw:
[20:58:24][I][remote.raw:041]: Received Raw:
[20:58:25][I][remote.raw:041]: Received Raw:
[20:58:25][I][remote.raw:028]: Received Raw: 8911, -4504, 538, -585, 536, -586, 536, -558, 563, -561, 532, -589, 539, -584, 540, -1684, 561, -558, 561, -1681, 538, -585, 538, -1707, 539, -558, 562, -1683, 538, -586, 562, -1658, 563, -558, 561, -561, 511, -1732, 538, -586, 537, -1680,
[20:58:25][I][remote.raw:041]:   562, -562, 534, -1711, 540, -585, 537, -1681, 564, -1685, 535, -585, 539, -1684, 561, -559, 562, -1683, 539, -608, 514, -1706, 538, -559, 561
[20:58:25][I][remote.raw:041]: Received Raw: 474
[20:58:26][I][remote.raw:041]: Received Raw:
[20:58:28][I][remote.raw:041]: Received Raw:
[20:58:28][I][remote.raw:028]: Received Raw: 8893, -4525, 539, -585, 536, -585, 538, -560, 562, -561, 533, -591, 537, -584, 537, -1686, 559, -560, 563, -1681, 538, -586, 537, -1684, 565, -557, 534, -1709, 541, -584, 535, -1685, 562, -559, 562, -560, 535, -1708, 539, -587, 536, -1684,
[20:58:28][I][remote.raw:041]:   559, -562, 538, -1708, 537, -584, 536, -1683, 562, -1683, 537, -587, 537, -1681, 561, -562, 535, -1710, 536, -587, 537, -1685, 561, -560, 561
[20:58:28][I][remote.raw:041]: Received Raw: 8622
[20:58:33][I][remote.raw:041]: Received Raw:
[20:58:33][I][remote.raw:041]: Received Raw: -2191
[20:58:34][I][remote.raw:041]: Received Raw:
[20:58:34][I][remote.raw:041]: Received Raw: 946, -5354
[20:58:39][I][remote.raw:041]: Received Raw:
[20:58:39][I][remote.raw:028]: Received Raw: -4502, 535, -586, 536, -585, 537, -560, 563, -560, 534, -588, 536, -586, 536, -1708, 536, -564, 557, -1682, 539, -587, 534, -1685, 566, -555, 562, -1683, 538, -585, 538, -1684, 560, -559, 562, -559, 533, -1712, 536, -586, 536, -1682, 561,
[20:58:39][I][remote.raw:041]:   -563, 533, -1712, 539, -583, 538, -1681, 563, -1684, 538, -585, 537, -1683, 562, -560, 559, -1684, 538, -587, 539, -1687, 556, -563, 559
[20:58:41][I][remote.raw:041]: Received Raw:
[20:58:42][I][remote.raw:041]: Received Raw:
[20:58:42][I][remote.raw:028]: Received Raw: -4525, 533, -588, 562, -559, 536, -561, 564, -562, 531, -588, 534, -589, 560, -1661, 562, -559, 560, -1685, 536, -587, 536, -1683, 561, -559, 562, -1684, 539, -583, 539, -1683, 558, -562, 559, -564, 510, -1734, 536, -584, 538, -1682, 561,
[20:58:42][I][remote.raw:041]:   -562, 510, -1733, 539, -583, 541, -1678, 563, -1684, 538, -586, 537, -1685, 562, -558, 561, -1684, 535, -590, 562, -1659, 563, -560, 560
[20:58:45][I][remote.raw:041]: Received Raw:
[20:58:45][I][remote.raw:028]: Received Raw: 8920, -4505, 536, -586, 538, -584, 540, -558, 565, -559, 512, -611, 537, -586, 538, -1685, 562, -560, 563, -1683, 539, -584, 539, -1708, 538, -560, 561, -1684, 540, -584, 539, -1685, 560, -560, 561, -564, 534, -1711, 538, -586, 561, -1660,
[20:58:45][I][remote.raw:041]:   559, -562, 538, -1708, 537, -585, 542, -1678, 539, -1706, 538, -584, 536, -1689, 560, -562, 562, -1682, 544, -581, 537, -1691, 556, -561, 564
[20:58:48][I][remote.raw:041]: Received Raw:
[20:58:48][I][remote.raw:028]: Received Raw: -4506, 539, -587, 536, -585, 541, -558, 559, -565, 532, -590, 535, -588, 540, -1706, 538, -559, 564, -1684, 538, -584, 540, -1709, 560, -537, 560, -1685, 535, -590, 538, -1684, 560, -560, 560, -565, 509, -1737, 537, -587, 534, -1686, 561,
[20:58:48][I][remote.raw:041]:   -562, 538, -1708, 537, -585, 538, -1685, 557, -1689, 535, -587, 537, -1686, 560, -561, 535, -1709, 538, -584, 537, -1685, 559, -561, 563
[20:58:51][I][remote.raw:041]: Received Raw:
[20:58:51][I][remote.raw:028]: Received Raw: -4503, 537, -588, 539, -560, 560, -560, 561, -563, 558, -562, 538, -587, 537, -1707, 535, -564, 561, -1683, 535, -586, 538, -1685, 557, -563, 562, -1683, 537, -586, 537, -1684, 560, -559, 564, -561, 534, -1710, 537, -586, 539, -1681, 559,
[20:58:51][I][remote.raw:041]:   -568, 531, -1713, 534, -586, 540, -1679, 563, -1682, 537, -587, 536, -1685, 560, -558, 535, -1712, 536, -585, 535, -1686, 562, -560, 561
[20:58:51][I][remote.raw:041]: Received Raw: -3827
[20:58:51][I][remote.raw:041]: Received Raw: -973, 3207
[20:58:51][D][sensor:093]: 'System - Uptime': Sending state 246.66701 s with 0 decimals of accuracy
[20:58:56][I][remote.raw:041]: Received Raw:
