Hi
I’m using official MELCloud integration to check on my Hydrobox unit. It correctly shows two entities accounting for Floor Heating and Water Heating. Question is: I’d like to monitor whether any of both is “on” as a status but I’m not able to see that info:
Operation only shows: Auto and force_hot_water…
@hanross2323 Here’s a super late response:
Unfortunately the water heater mode has only the two states shown in the list. The off mode would need to be emulated. It is also impossible to turn on/off the water and flow heating separately so I chose not to add the confusion in the mix.
You can still check the current status of the water heater throught the extra state property status
. However, it does not have simple on/off statuses.
