MELCloud unknown error on registration
Hello!
I try to connect MELCloud to HASS and after entering the username and password I get an “Unkonwn error”.
Please help!
Here’s the entry from the log.
Logger: aiohttp.server
Source: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:448
First occurred: 18:56:01 (1 occurrences)
Last logged: 18:56:01
Error handling request
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 567, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 222, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 122, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in async_configure
    result = await self._async_configure(flow_id, user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 414, in _async_configure
    result = await self._async_handle_step(
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 517, in _async_handle_step
    result: _FlowResultT = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/melcloud/config_flow.py", line 78, in async_step_user
    return await self._create_client(username, password=user_input[CONF_PASSWORD])
  File "/usr/src/homeassistant/homeassistant/components/melcloud/config_flow.py", line 48, in _create_client
    acquired_token = await pymelcloud.login(
  File "/usr/local/lib/python3.12/site-packages/pymelcloud/__init__.py", line 22, in login
    _client = await _login(email, password, session,)
  File "/usr/local/lib/python3.12/site-packages/pymelcloud/client.py", line 55, in login
    response.get("LoginData").get("ContextKey"),
AttributeError: 'NoneType' object has no attribute 'get'
Hi, were you able to solve this? I’m having the same problem.
Unfortunately no. And it seems we’re the only two using it… :smiley:
Still waiting for a help… :sleeping:
But there is an open bugfix request
MELCLOUD log in fail · Issue #133703 · home-assistant/core · GitHub
Hi, I’m having the same issue as well. Has anyone solved it?
Not yet. Please contact the authors in the GitHub issue report to let them know I’m not the only one. The more we are, the quicker the solution will be.
