Dear community,
My SD card crashed (as in, not readable at all) including all the backups of my Home-Assistant installation. Shame on me and lesson learned.
However, after a fresh clean install of Home Assistant OS on my Raspberry Pi 3b with a Z-Wave module installed on the GPIO pins I installed the Z-Wave JS Addon. Now my problem is, that it uses constantly around 40% CPU usage and the memory consumption keeps rising until the entire Raspberry Pi becomes unresponsive and I have to pull the power plug to do a reboot. If I stop the Addon before, it releases the memory and everything is back to normal.
Now my issue is, how do I debug this? I don’t see any error message in the addon’s logs. This is when I am launching on debug log level.
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/config.sh
[15:33:54] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
[15:34:01] INFO: Virtual Machine not detected, enabling soft-reset
cont-init: info: /etc/cont-init.d/config.sh exited 0
cont-init: info: running /etc/cont-init.d/structure.sh
cont-init: info: /etc/cont-init.d/structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun zwave_js (no readiness notification)
s6-rc: info: service legacy-services successfully started
[15:34:05] INFO: Successfully send discovery information to Home Assistant.
2022-10-18T13:34:18.477Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2022-10-18T13:34:18.503Z DRIVER version 10.3.0
2022-10-18T13:34:18.505Z DRIVER
2022-10-18T13:34:18.507Z DRIVER starting driver...
2022-10-18T13:34:18.606Z DRIVER opening serial port /dev/ttyAMA0
2022-10-18T13:34:18.670Z DRIVER serial port opened
2022-10-18T13:34:18.676Z SERIAL » [NAK] (0x15)
Any pointers help would be really apreciated.
