I have installed hass.io on top of Ubuntu 19.10 following the generic linux instructions found here: https://www.home-assistant.io/hassio/installation/ in a hyper-v VM. I should also note that I am accessing my z-wave stick via USBIP as I do not have a host that can passthrough devices as it’s too old to support ACS.
If I add the z-wave integration and start my network, the memory demand as reported by hyper-v steadily increases and the processor utilization gets pegged at 100%. Eventually everything becomes quite unusable and I have to reboot the system. If I uninstall the z-wave integration and reboot I have no problems.
Anyone have any ideas or should I post an issue on the github? I’ve seen others have problems with this integration and memory leaks in the past that were solved by an update, but I think something must have regressed again.
