Hi all, I have a problem with memory consumption. It grows until the node process crash.
I have a very simple flow that switch on / off a switch entity on HA.
I’m running hass.io latest version on r pi 3 B+.
Hi, I think I’m having the same sort of problem HA core same r pi.
I’ve tried running: node-red-pi --max-old-space-size=256 &
as suggested: – NodeRED - https://nodered.org/docs/getting-started/raspberrypi
I’m debating is it time for the newer pi
Best of luck,
Hello there,
any update on your memory leak? I’m pretty sure I’ve got the same problem
After uninstalling Node Red it seems to be flat again, so I’ll delete flows one by one to see where’s the problem, but if you have any clue I’ll be tnakful !
Hi, nope.
I switched to dietpi.
Now I run home assistant, node red, mqtt, two ffmpeg cameras and some integrations with this result.
Note: I restarted yesterday at 8h00 pm.
The memory use usually stays between 50% and 60%
stefano
