I’ve had some random reboots of my docker container and I suspect this might be the culprit. I will see if I can reproduce this week to provide some additional data points.
noone else experience this leak? Maybe because I am on a small device. I hadn’t this leak on Domoticz which is also using open-zwave. I see some memory leak fixes (open-zwave#1504) on this project, maybe it will be fixed soon on rpi.
Seem to have been fixed, or at least partially fixed, with 0.77.2: .
It still increase memory usage over time, but much slower. But I am not sure which changes did that.
All my Z-Wave devices works, but they always appear in “Initializing state”: .
It did not do that in previous versions (only the SRT321 which is i sleep mode because on battery)
I’ve only got a couple of devices connected through a USB adapter, but my memory usage is generally as flat as a tack; been that way for as long as I’ve used Z-wave.
I’m seeing the same behavior as @gsemet on 77.3; my memory use rises steadily by ~12 percentage points per day. I have about 10 Z-wave devices. I’ve also had some serious connection issues with a few of the devices over the past 2 weeks (door sensors never updating to “closed”, lock dropping every request even after heal/refresh).
I am running on 0.79.3 and I have a similar issue. My network is currently still small but with long distances, so I am not able to have 2 or 3 redundant paths for each device. But nevertheless it was working perfectly for several months. Since a couple of weeks I have also troubles with my Fibaro Door Sensors not reflecting the correct state…
I wondered for a long time why my Pi3 would freeze every now and then after a while. I added monitoring now and see the same memory use increase @ about 10-isch % per day previous version 0.79 as well as current 0.8…
I would love to dig into this a bit. Any good pointers to start debugging this on hassio?
Thx in advance!
I personally have the same problem but no idea where to start debugging. My Hassio on RPi3 crashes regularly now and has done for a few months. I only recently realized it was a memory leak problem but I don’t use the MQTT broker which apparently tends to be one of the culprits.
