I have had some reboot’s because of this.
I’m running HA on Virtual box, and when is reboots I always loose my zigbee comm. It needs to be powered off before restart.
Anyone who can guide me in to finding out what is causing this spike?
Can you see your network utilization at that time?
The memory and CPU load could be from a large network transfer and if that network transfer is occuring over WiFi, then it could cause your Zigbee to die, if the WiFi and Zigbee are on the same frequency.
Good Idea, Thanks! I have a Unify network with controller running, so I get lots of information from my network. I however don’t see any (increased) activity’s at the time of the spike.
No, never found the cause, but at some point is stopped being an issue for my system. I also moved from virtual box to dedicated pc with haos that dramatically improved performance
Thanks for the update!
I wish you could find the cause, but it’s nice to know that I’m not the only one with this problem. Maybe there will be someone someday who can determine what component/element of the home assistant performs memory intensive tasks at 6:10 AM.
