Memory usage above 80%: time for a new Pi?
Hi there!
I’ve be running HA on a Raspberry Pi 3 for around 4 years now. No problems so far. However, I added an USB Zigbee adapter and some new integrations.
Memory usage is now always above 80%. Let’s say it’s in between 80-90%. I notice some laggy automations now.
Reading this, I see this recomendation:
In general, we recommend using a board with at least 1 GB of memory and make sure to stay well below 80% memory utilization.
Time to get a Pi with 2 GB of RAM?
Definitely time to upgrade. I had a Pi3 and pretty quickly ran into that same limitation. Personally I think 4GB is the minimum if you’re upgrading anyway.
In the short term why not increase the swap file size to give more memory.
Thanks. Definitely, i’m going to upgrade. It’s been many years running HA on a Pi. It’s time to move to something with a little more power and stability (not depending on SD cards). I might go for an Intel NUC with 8 GM of RAM or similar.
I’m just reading and see what suits my needs :slight_smile:
I’ll try that out while I search for the final solution! Thanks
I went with an old laptop I had sitting on a shelf collecting dust. Honestly never even checked the specs, but night and day quicker than my Pi 3. Just tossing it out there as a cheap/free upgrade option. I even replaced the battery so I have a built-in UPS and upped the RAM to 8GB for a few bucks.
RPI3 runs at about 5-6 W. Laptop will run a good bit higher I suspect closer to 20 W. If you want to extend the battery life limit the change and discharge levels to 20-80% capacity. My experience at work is UPS work well until you need them.
In my case it runs just over 10W, a little more than a Pi but would still take a long time to offset the cost of buying something new. I’ll keep it until it dies or I have something else on-hand that’s better.
Agreed, although in my case I don’t really need it (none of my other network equipment has a UPS). The motherboard also appears to be managing the charge in an intelligent way, so I’m not worried. I honestly only bought it to cover the occasional power-flicker; the laptop doesn’t automatically turn back on when power is restored and it’s off.
My laptops aren’t fit for much when I’ve finished with them after 6 years. I have salvaged a few 18650’s from them that I use in outdoor solar projects. Currently using a small CPU fan from a desktop I bought back in 2000 to cool my rpi4. The heat sink is on my RTL-SDR. Hate to throw any tech away. Desolder every capacitor I can find.
Finally, I decided to go for a miniPC with a N100 processor, 16 GB RAM and 512 SSD NVMe (Beelink 12 Pro).
I will install HA over Proxmox. I like this setup because I’m also running a Audiobookshelf and Plex servers, which I can move to Proxmox on that machine :slight_smile:
Thanks for your help!
Make it easy for yourself and follow this guide. Tteck’s scripts are a godsend!
Looks awesome!! Thanks a million
I finally moved my HA instance from the Pi 3 to a Beelink miniPC. Installed Proxmox, restored HA from a backup and… everything running way much faster! I should’ve done this before! Impressive performance now :smiley:
welcome to proxmox :slight_smile:
you are not gonna go back lol
i also moved my routing capabilities to proxmox (a openwrt VM), a dedicated LXC for downloading (in a dmz), jellyfin, openmediavault and nextcloud
you’ll see how fast you are going to consume 16Gb of ram :slight_smile:
