Hi, I’m trying to display the percent of memory usage but in my service system monitor there are only memory usage and memory use.
Where do I find the percentage?
Are you referring to this integration? If so, then it could be that the entity you want is disabled by default.
It is not listed in this integration, but I saw that some user have it somehow
sensor.memory_usage is the percentage
sensor.memory_use is the data measurement (MB/GB)
I checked twice yesterday and it was a value of MiB, now it is in %…
Thanks anyway, you made my day
I checked the log… I was using memory_usage
