Using the original device config from @jasonc I changed the initial definition to match my device:
fingerprint: [{modelID: 'TS011F', manufacturerName: '_TZ3210_pfbzs1an'}],
zigbeeModel: ['TS011F'],
model: 'SPUSB02',
vendor: 'Mercator',
description: 'Double Power Point with USB',
Like jasonc’s original observations, the power-related properties are exposed under the “left” end-point, even though they represent the whole devices power usage.
I’ve only had a quick play with this so far, and am still trying to figure out what certain parts of the config do (like all the reporting calls in configure…)
You replied to my comment on github, weirdly I never received a message. Thanks for yhe info, I will be pulling them out and trying again!
Pity about the single power measurement, but not to worry.
I am hoping that all their devices work well and have z2m support, as they are affordable Australian devices. Looking forward to simple automation of my house
Note that the power reporting on my double adapter had stopped working a few months ago - was reporting 27W usage no matter what was plugged in or turned on. I’d tried rejoining it to the Zigbee network and had no success so had sort of given up on it. Then a couple of days ago we had a power outage and afterwards - magic - power usage is working again.
Guess I should have tried powering cycling the circuit it was on but didn’t occur to me at the time. Thought I would share in case anyone else has a similar issue with it.
I find that Zigbee2MQTT now identifies my outdoor Mercator ikuü double GPO. However, the interview does not complete. Has anyone else experienced this and are competent to understand why?
