any progress to why I don’t get the device tracker?
not yet, I’ll add some more debug code…
okay I’ll be patient
Hi, this weekend i got some time to rework my configuration which wasn’t working at all before I updated to the new variant.
Is there a way to directly use attributes in lovelace picture-element-cards? If no I would strongly recommend to go back to the single sensor elements. Not everybody is using attribute cards. If theres an other way please tell me. For now i will use template sensors and extract the attributes…
How did you geth that gauge into the picture element? Would you mind to share your config?
Edit: (Oh my, you are Manuel82, from which I copied from the start… Seems we did the same thing this weekend: reworking your original config to fit the new sensors/attributes…
Using template sensors is the way to go.
I have just finished my setup, based on the setup of @Manuel82. I’ll share my config very soon, just need to do some clean-up.
Here are my template sensors to get you started. I’ll try to post the rest of the config in another (decent) way:
1rtf858_distance_since_start:
value_template: "{{state_attr('sensor.1rtf858_odometer', 'distanceStart')| float}}"
friendly_name: 'Distance Since Start'
unit_of_measurement: 'km'
1rtf858_average_speed_since_start:
value_template: "{{state_attr('sensor.1rtf858_odometer', 'averageSpeedStart')| float}}"
friendly_name: 'Average Speed Since Start'
unit_of_measurement: 'km/u'
1rtf858_drive_time_since_start:
value_template: >-
{% set time = state_attr('sensor.1rtf858_odometer', 'drivenTimeStart')| float %}
{% set minutes = (time % 60) | int %}
{% set hours = (time / 60) | int %}
{% set days = (time / 86400) | int %}
{%- if time < 60 -%}
Less than a minute
{%- else -%}
{%- if hours > 0 -%}
{%- if hours == 1 -%}
1 hour
{%- else -%}
{{ hours }} hours
{%- endif -%}
{%- endif -%}
{%- if minutes > 0 -%}
{%- endif -%}
{%- if minutes == 1 -%}
1 minute
{%- else -%}
{{ minutes }} minutes
{%- endif -%}
{%- endif -%}
{%- endif -%}
friendly_name: 'Time Driven Since Start'
unit_of_measurement: ''
1rtf858_distance_since_reset:
value_template: "{{state_attr('sensor.1rtf858_odometer', 'distanceReset')| float}}"
friendly_name: 'Distance Since Reset'
1rtf858_liquid_consumption_start:
value_template: "{{state_attr('sensor.1rtf858_odometer', 'liquidconsumptionstart')| float}}"
friendly_name: 'Consumption Since Start'
unit_of_measurement: 'l/100km'
1rtf858_liquid_consumption_reset:
value_template: "{{state_attr('sensor.1rtf858_odometer', 'liquidconsumptionreset')| float}}"
friendly_name: 'Consumption Since Reset'
1rtf858_liquid_range:
value_template: "{{state_attr('sensor.1rtf858_odometer', 'rangeliquid')| float}}"
friendly_name: 'Range Liquid'
# 1rtf858_tank_level:
# value_template: "{{state_attr('sensor.1rtf858_odometer', 'tanklevelpercent')| float}}"
# friendly_name: 'Tank Level'
# unit_of_measurement: '%'
1rtf858_tire_pressurebar_front_left:
value_template: "{{state_attr('binary_sensor.1rtf858_tire_warning', 'tirepressureFrontLeft')| float}}"
friendly_name: 'Tire Pressure Front Left'
1rtf858_tire_pressurebar_front_right:
value_template: "{{state_attr('binary_sensor.1rtf858_tire_warning', 'tirepressureFrontRight')| float}}"
friendly_name: 'Tire Pressure Front Right'
1rtf858_tire_pressurebar_rear_left:
value_template: "{{state_attr('binary_sensor.1rtf858_tire_warning', 'tirepressureRearLeft')| float}}"
friendly_name: 'Tire Pressure Rear Left'
1rtf858_tire_pressurebar_rear_right:
value_template: "{{state_attr('binary_sensor.1rtf858_tire_warning', 'tirepressureRearRight')| float}}"
friendly_name: 'Tire Pressure Rear Right'
1rtf858_door_front_right:
value_template: >-
{% if is_state_attr('sensor.1rtf858_lock', 'doorStateFrontRight', 'DOOR_CLOSED_AND_DOOR_LOCKED')%}
Closed
{% else %}
Open
{% endif %}
friendly_name: 'Door Status Front Right'
1rtf858_door_front_left:
value_template: >-
{% if is_state_attr('sensor.1rtf858_lock', 'doorStateFrontLeft', 'DOOR_CLOSED_AND_DOOR_LOCKED')%}
Closed
{% else %}
Open
{% endif %}
friendly_name: 'Door Status Front Left'
1rtf858_door_rear_right:
value_template: >-
{% if is_state_attr('sensor.1rtf858_lock', 'doorStateRearRight', 'DOOR_CLOSED_AND_DOOR_LOCKED')%}
Closed
{% else %}
Open
{% endif %}
friendly_name: 'Door Status Rear Right'
1rtf858_door_rear_left:
value_template: >-
{% if is_state_attr('sensor.1rtf858_lock', 'doorStateRearLeft', 'DOOR_CLOSED_AND_DOOR_LOCKED')%}
Closed
{% else %}
Open
{% endif %}
friendly_name: 'Door Status Rear Left'
1rtf858_trunk_status:
value_template: >-
{% if is_state_attr('sensor.1rtf858_lock', 'trunkStateRollup', 'CLOSED_AND_LOCKED')%}
Closed
{% else %}
Open
{% endif %}
friendly_name: 'Trunk Status'
1rtf858_window_front_right:
value_template: >-
{% if is_state_attr('binary_sensor.1rtf858_windows_closed', 'windowstatusfrontright', 'CLOSED')%}
Closed
{% else %}
Open
{% endif %}
friendly_name: 'Window Status Front Right'
1rtf858_window_front_left:
value_template: >-
{% if is_state_attr('binary_sensor.1rtf858_windows_closed', 'windowstatusfrontleft', 'CLOSED')%}
Closed
{% else %}
Open
{% endif %}
friendly_name: 'Window Status Front Left'
1rtf858_window_rear_right:
value_template: >-
{% if is_state_attr('binary_sensor.1rtf858_windows_closed', 'windowstatusrearright', 'CLOSED')%}
Closed
{% else %}
Open
{% endif %}
friendly_name: 'Window Status Rear Right'
1rtf858_window_rear_left:
value_template: >-
{% if is_state_attr('binary_sensor.1rtf858_windows_closed', 'windowstatusrearleft', 'CLOSED')%}
Closed
{% else %}
Open
{% endif %}
friendly_name: 'Window Status Rear Left'
1rtf858_windows_allclosed:
value_template: >-
{% if is_state_attr('binary_sensor.1rtf858_windows_closed', 'windowstatusrearleft', 'CLOSED') and is_state_attr('binary_sensor.1rtf858_windows_closed', 'windowstatusrearright', 'CLOSED') and is_state_attr('binary_sensor.1rtf858_windows_closed', 'windowstatusfrontleft', 'CLOSED') and is_state_attr('binary_sensor.1rtf858_windows_closed', 'windowstatusfrontright', 'CLOSED') %}
Closed
{% else %}
Open
{% endif %}
friendly_name: 'All Windows Closed'
1rtf858_doors_allclosed:
value_template: >-
{% if is_state_attr('sensor.1rtf858_lock', 'doorsClosed', true)%}
Closed
{% else %}
Open
{% endif %}
friendly_name: 'All Doors Closed'
1rtf858_warning_washwater:
value_template: >-
{% if is_state_attr('binary_sensor.1rtf858_engine_light_warning', 'warningwashwater', false)%}
off
{% else %}
on
{% endif %}
friendly_name: 'Warning WashWater'
1rtf858_warning_breakfluid:
value_template: >-
{% if is_state_attr('binary_sensor.1rtf858_engine_light_warning', 'warningbrakefluid', false)%}
off
{% else %}
on
{% endif %}
friendly_name: 'Warning BreakFluid'
Sure, here is my config:
I’m using a high res main image to make the panel resizable without loosing the correct positioning of the elements even on 4k display ( https://i.imgur.com/rZLDq7b.png )
resources:
- type: js
url: /local/plugins/card-tools.js?v=1
- type: js
url: /local/plugins/card-modder.js?v=1
- type: js
url: /local/plugins/bar-card.js?v=1
- type: js
url: /local/plugins/bignumber-card.js?v=1
- type: module
url: /local/plugins/compact-custom-header.js?v=1.2.0
- type: module
url: /local/plugins/card-mod.js?v=0.0.1
- url: /local/plugins/button-card.js?v=1.11.1
type: module
cch:
options: clock
clock_format: 24
clock_date: true
title: Casa
######### MACCHINA
- cards:
- elements:
- card:
entity: sensor.livello_serbatoio
title: Carburante
type: gauge
unit: '%'
style:
'--base-unit': 2.2vw
'--paper-card-background-color': '#000000'
left: 37%
top: 17.5%
type: 'custom:card-modder'
- card:
entity: sensor.fe270je_odometer
scale: 1vw
title: Chilometri percorsi
type: 'custom:bignumber-card'
style:
'--paper-card-background-color': transparent
left: 56.5%
top: 19%
- card:
entity: sensor.consumo_recente
scale: 1vw
title: Consumo recente
style:
left: 45%
top: 19%
- card:
entity: sensor.pressione_a_sx
scale: 0.8vw
style:
left: 13%
top: 59.3%
- card:
entity: sensor.pressione_a_dx
scale: 0.8vw
style:
left: 27.2%
top: 59.5%
- card:
entity: sensor.pressione_p_sx
scale: 0.8vw
style:
left: 13%
top: 80%
- card:
entity: sensor.pressione_p_dx
scale: 0.8vw
style:
left: 27.2%
top: 80.2%
- entity: lock.fe270je_lock
state_image:
locked: /local/portiere_chiuse.png
unlocked: /local/portiere_aperte.png
style:
left: 83%
max-width: 3.4%
top: 30.5%
tap_action:
action: none
type: image
- entity: sensor.stato_tettuccio
state_image:
TILT_SLIDE_SUNROOF_CLOSED: /local/portiere_chiuse.png
TILT_SLIDE_SUNROOF_OPEN: /local/portiere_aperte.png
style:
left: 68.3%
max-width: 2.5%
top: 20.5%
tap_action:
action: none
type: image
- entity: sensor.liquido_freni
state_image:
'False': /local/check.png
'True': /local/warning.png
style:
left: 76.8%
max-width: 2.5%
top: 20.5%
tap_action:
action: none
type: image
- entity: sensor.liquido_refrigerante
state_image:
style:
left: 81.3%
max-width: 2.5%
top: 20.5%
tap_action:
action: none
type: image
- entity: sensor.liquido_lavavetri
state_image:
style:
left: 85.7%
max-width: 2.5%
top: 20.5%
tap_action:
action: none
type: image
image: /local/macchina6.png
style:
transform: none
type: picture-elements
panel: true
path: macchina
title: Macchina
I have now spent several hours, coffees and too many ciggies and still stuck.
The component seem to load correctly. HA does not complain. I have enabled the detailed log and messages show that I am connected and that I am getting responses. However, no sensors (binary and otherwise) show up in HA.
Question. Do I need to subscribe to any Mercedes dev API? Or is it a service on the Me-portal. for my MERCEDES-BENZ E-CLASS T-Model (S212) E 200 CDI (212.205) 2013 136Hk - there are no services available on the portal.
I am using the Me-bluetooth adapter connected to my phone. Based in Sweden. Data is visible in the portal.
state_WDXXXXXXXXXXXXX.json shows:
{"dynamic": {}, "aggregated": {"lastJourney": null}}
feat_WDXXXXXXXXXXXXX.json shows:
{"metadata": {"appSections": {"productsEnabled": false, "mobilityEnabled": true, "newsEnabled": true}
"featureEnablements": [{"name": "MYCAR_INFO_BUTTON", "enablement": "INVISIBLE"}, {"name": "EV_CHARGING_POINTS_TOGGLE", "enablement": "ACTIVATED"}, {"name": "CHARGING_CLIMA_CONTROL_DEPARTURETIME_TEMPERATURE_LINKOUT_TOGGLE", "enablement": "ACTIVATED"}, {"name": "CONNECT_SERVICE_MANAGEMENT_TOGGLE", "enablement": "INVISIBLE"}, {"name": "PARKING_OFF_STREET", "enablement": "INVISIBLE"}, {"name": "CHARGING_CLIMA_CONTROL_CHARGING_DEMAND_NOTIFICATION_TOGGLE", "enablement": "ACTIVATED"}, {"name": "ADD_VEHICLE", "enablement": "ACTIVATED"}, {"name": "EMOBILITY_SERVICE_PROVIDER", "enablement": "INVISIBLE"}, {"name": "ENERGIZING_COACH", "enablement": "INVISIBLE"}, {"name": "LEA_ASSISTANT", "enablement": "INVISIBLE"}, {"name": "REMOTE_STATUS_RANGE_CRITICAL_TOGGLE", "enablement": "INVISIBLE"}, {"name": "DOOR_TO_DOOR_NAVIGATION", "enablement": "INVISIBLE"}, {"name": "COLLISION_ALARM", "enablement": "INVISIBLE"}, {"name": "VEHICLE_AUTHORIZATION_CHANGE_EVENT_TOGGLE", "enablement": "INVISIBLE"}, {"name": "REMOTE_ENGINE_START", "enablement": "INVISIBLE"}, {"name": "AUX_HEAT", "enablement": "INVISIBLE"}, {"name": "S2C_MBA", "enablement": "INVISIBLE"}, {"name": "CHARGING_CLIMA_CONTROL_19B_TOGGLE", "enablement": "ACTIVATED"}, {"name": "VALET_PROTECT", "enablement": "INVISIBLE"}, {"name": "CONCIERGE", "enablement": "INVISIBLE"}, {"name": "VEHICLE_SERVICE_DASHBOARD", "enablement": "INVISIBLE"}, {"name": "MYCAR_PHASE_1", "enablement": "INVISIBLE"}, {"name": "PRIVATE_CAR_SHARING", "enablement": "INVISIBLE"}, {"name": "REMOTE_STATUS_RANGE_HIGHLIGHT_TOGGLE", "enablement": "INVISIBLE"}, {"name": "REMOTE_DOUBLE_DOOR_LOCK", "enablement": "INVISIBLE"}, {"name": "CHARGING_CLIMA_CONTROL", "enablement": "INVISIBLE"}, {"name": "REMOTE_STATUS", "enablement": "INVISIBLE"}, {"name": "S2C_RIF", "enablement": "INVISIBLE"}, {"name": "SMART_HOME", "enablement": "INVISIBLE"}, {"name": "CHARGING_CLIMA_CONTROL_TOGGLE", "enablement": "ACTIVATED"}, {"name": "VOICE_ADDRESS_SEARCH", "enablement": "ACTIVATED"}, {"name": "VEHICLE_LOCATOR", "enablement": "INVISIBLE"}, {"name": "REMOTE_STATUS_SUNROOF_LEAF_PAGE_TOGGLE", "enablement": "INVISIBLE"}, {"name": "REMOTE_CONFIGURATION", "enablement": "INVISIBLE"}, {"name": "FIND_VEHICLE", "enablement": "ACTIVATED"}, {"name": "COMMUTE_ALERT", "enablement": "INVISIBLE"}, {"name": "MAXSOC_CONFIGURATION", "enablement": "INVISIBLE"}, {"name": "CHARGING_CLIMA_CONTROL_PRECOND_NOTIFICATION_TOGGLE", "enablement": "ACTIVATED"}, {"name": "DESIGNATED_DRIVER", "enablement": "INVISIBLE"}, {"name": "CHARGING_CLIMA_CONTROL_BATTERY_ANIMATION_TOGGLE", "enablement": "ACTIVATED"}, {"name": "WEEKLY_PROFILE_CONFIGURATION", "enablement": "INVISIBLE"}, {"name": "DAYNIGHT_TARIFF_LINKOUT_TOGGLE", "enablement": "ACTIVATED"}, {"name": "S2C_INFO_TEXT", "enablement": "ACTIVATED"}, {"name": "EV_RANGE_ASSIST", "enablement": "INVISIBLE"}, {"name": "ONEWEB_LINKOUT_TOGGLE", "enablement": "ACTIVATED"}, {"name": "SPEED_ALERT", "enablement": "INVISIBLE"}, {"name": "INBOX", "enablement": "ACTIVATED"}, {"name": "PREDICTIVE_SUGGESTIONS", "enablement": "INVISIBLE"}, {"name": "PROFILE_PICTURE_TOGGLE", "enablement": "INVISIBLE"}, {"name": "PARKING_ON_STREET_PAYMENT", "enablement": "INVISIBLE"}, {"name": "VEHICLE_TRACKING", "enablement": "INVISIBLE"}, {"name": "TRIPS_TOGGLE", "enablement": "INVISIBLE"}, {"name": "EV_CORE_CHARGING_STATION_PROVIDER", "enablement": "INVISIBLE"}, {"name": "CAR_ALARM", "enablement": "INVISIBLE"}, {"name": "INSTANT_CHARGE_PROGRAM", "enablement": "INVISIBLE"}, {"name": "STARTER_BATTERY", "enablement": "INVISIBLE"}, {"name": "IN_CAR_DELIVERY", "enablement": "INVISIBLE"}, {"name": "PARKING_C2C", "enablement": "INVISIBLE"}, {"name": "RANGE_ON_MAP", "enablement": "INVISIBLE"}, {"name": "PARKING_ON_STREET", "enablement": "INVISIBLE"}, {"name": "TRAFFIC_VIOLATION_NOTIFICATION", "enablement": "INVISIBLE"}, {"name": "CHARGING_CLIMA_CONTROL_MAXSOC_TOGGLE", "enablement": "ACTIVATED"}, {"name": "LOCAL_PLATE_RESTRICTION_NOTIFICATION", "enablement": "INVISIBLE"}, {"name": "PARKING", "enablement": "INVISIBLE"}, {"name": "TEMPERATURE_SEAT_CLIMATE_CONTROL", "enablement": "INVISIBLE"}, {"name": "SERVICE_STATUS_CHANGE_EVENT_TOGGLE", "enablement": "INVISIBLE"}, {"name": "QR_CODE", "enablement": "ACTIVATED"}, {"name": "PARKING_REALTIME", "enablement": "INVISIBLE"}, {"name": "CHARGING_CLIMA_CONTROL_CHARGING_NOTIFICATION_TOGGLE", "enablement": "ACTIVATED"}, {"name": "DOOR_STATUS_DETAILS", "enablement": "INVISIBLE"}, {"name": "PARKING_OFF_STREET_BOOKING", "enablement": "INVISIBLE"}, {"name": "CHARGING_CLIMA_CONTROL_SELECTED_SOC_NOTIFICATION_TOGGLE", "enablement": "INVISIBLE"}, {"name": "REMOTE_DOOR_LOCK", "enablement": "INVISIBLE"}, {"name": "MARKET_DISABLED", "enablement": "INVISIBLE"}, {"name": "CONNECTED_CAR", "enablement": "INVISIBLE"}, {"name": "CHARGING_CLIMA_CONTROL_19B_NOTIFICATION_TOGGLE", "enablement": "INVISIBLE"}, {"name": "TRAFFIC_VIOLATION", "enablement": "INVISIBLE"}, {"name": "EV_CHARGING_POINTS", "enablement": "INVISIBLE"}, {"name": "WINDOW_LEAF_PAGE", "enablement": "INVISIBLE"}, {"name": "ANDROID_BLUETOOTH_FEATURES", "enablement": "INVISIBLE"}, {"name": "EV_CHARGING_POINTS_DASHBOARD_SHORTCUT", "enablement": "ACTIVATED"}, {"name": "MYCAR_PHASE_0", "enablement": "INVISIBLE"}, {"name": "LOCAL_PLATE_RESTRICTION", "enablement": "INVISIBLE"}, {"name": "NEWSFEED", "enablement": "ACTIVATED"}, {"name": "PRODUCT_TAB_MBRACE", "enablement": "INVISIBLE"}, {"name": "LIFESTYLE_CONFIGURATOR", "enablement": "INVISIBLE"}, {"name": "PRODUCTION_TRACKER", "enablement": "ACTIVATED"}, {"name": "ME_CLUB", "enablement": "INVISIBLE"}, {"name": "PERSONALIZED_NEWSFEED", "enablement": "ACTIVATED"}, {"name": "APPLY_CREDIT", "enablement": "INVISIBLE"}, {"name": "PHYD_INSURANCE", "enablement": "INVISIBLE"}, {"name": "PRODUCT_FINDER", "enablement": "INVISIBLE"}, {"name": "FINANCIAL_CALCULATOR", "enablement": "INVISIBLE"}, {"name": "MY_ACCOUNT", "enablement": "INVISIBLE"}, {"name": "FINACIAL_CONTRACT_MGMT", "enablement": "INVISIBLE"}, {"name": "ONLINE_OFFLINE_MODE", "enablement": "ACTIVATED"}, {"name": "ENABLED_CAR_IMAGE_CACHE", "enablement": "INVISIBLE"}, {"name": "DISPLAY_LOGIN_REGISTER", "enablement": "INVISIBLE"}, {"name": "UNLIMITED_CONSUMPTION_TOGGLE", "enablement": "ACTIVATED"}, {"name": "DAIVB_EMPTY_ERROR", "enablement": "INVISIBLE"}, {"name": "DISPLAY_SERVICEAGREEMENTS_PROMPT", "enablement": "INVISIBLE"}, {"name": "DISPLAY_ACTIVATE_SERVICE", "enablement": "ACTIVATED"}, {"name": "DISPLAY_EULA_DATA_PROTECTION", "enablement": "ACTIVATED"}, {"name": "VEHICLE_RULES_VALIDATION", "enablement": "INVISIBLE"}, {"name": "DISPLAY_APP_PROVIDER", "enablement": "ACTIVATED"}, {"name": "UNIT_SELECTION", "enablement": "ACTIVATED"}, {"name": "ASK_USER_RATING", "enablement": "INVISIBLE"}, {"name": "DISPLAY_SETTINGS_TOGGLE", "enablement": "ACTIVATED"}, {"name": "CAR2GO", "enablement": "INVISIBLE"}, {"name": "MOOVEL", "enablement": "INVISIBLE"}, {"name": "MYTAXI", "enablement": "ACTIVATED"}, {"name": "MOBILITY_SERVICES", "enablement": "ACTIVATED"}, {"name": "SHOP", "enablement": "INVISIBLE"}, {"name": "ONLINE_BOOKING_REQUEST", "enablement": "ACTIVATED"}, {"name": "DEALER_SEARCH", "enablement": "ACTIVATED"}, {"name": "HOW_TO_VIDEOS", "enablement": "ACTIVATED"}, {"name": "ACCIDENT_CLAIM", "enablement": "INVISIBLE"}, {"name": "DASHBOARD_HELP", "enablement": "ACTIVATED"}], "userVehicleState": "LEGACY"}, "staticVehicleData": {"vin": "WDXXXXXXXXXXXXX", "imageUrl": null, "model": "E 200 CDI BlueEFFICIENCY Estate", "licensePlate": "XYZ123", "initialRegistration": null, "color": "polar white", "equipmentLine": "Classic", "upholstery": "Black ARTICO man-made leather", "displacement": null, "output": "136 PS", "fuel": null, "transmission": "automatic transmission", "modelYear": null, "euroStandard": null, "baumuster": "212205", "specialEquipment": ["P:803"], "geoInfo": null, "unlimitedConsumption": false, "supportsDayNightTariff": false, "vehicleRules": {"overallRangeLiquidAndElectricPercent": "25", "locked": "true"}}}
Thanks for any assistance!!
/Mikael
Hi @ThePapaMaan,
The Bluetooth adapter will not work with this integration.
The state_WDXXXXXXXXXXXXX.json Is empty, that means the api delivers no data.
Sorry, I can’t help here.
Rene
What a b.mmer. ok. Thanks for your quick response!
Hi @ReneNulschDE
I integrated your old project mercedesmebeta for simulator to HA, and see exception from log:
2019-07-26 10:24:03 ERROR (SyncWorker_3) [mercedesmejsonpy.controller] url: https://api.mercedes-benz.com/experimental/connectedvehicle/v1/vehicles, headers: {'content-type': 'application/json', 'Authorization': 'Bearer d0c68dd4-c939-4a0f-8cf8-xxxxxxxxxxxx'}, proxies: None
NoneType: None
2019-07-26 10:24:09 ERROR (SyncWorker_3) [mercedesmejsonpy.controller] res.json: [{'id': '6DE25C138CECE3B10B', 'licenseplate': 'S-GG-613', 'finorvin': '1HMA8C654H2B0B551'}]
NoneType: None
2019-07-26 10:24:09 ERROR (SyncWorker_3) [mercedesmejsonpy.controller] url: https://api.mercedes-benz.com/experimental/connectedvehicle/v1/vehicles/6DE25C138CECE3B10B, headers: {'content-type': 'application/json', 'Authorization': 'Bearer d0c68dd4-c939-4a0f-8cf8-xxxxxxxxxxxx'}, proxies: None
NoneType: None
2019-07-26 10:24:10 ERROR (SyncWorker_3) [mercedesmejsonpy.controller] res.json: {'id': '6DE25C138CECE3B10B', 'licenseplate': 'S-GG-613', 'salesdesignation': 'E 400 4MATIC Limousine', 'finorvin': '1HMA8C654H2B0B551', 'nickname': 'mmueller', 'modelyear': '2017', 'colorname': 'iridiumsilber metallic', 'fueltype': 'Benzin', 'powerhp': '333', 'powerkw': '245', 'numberofdoors': '5', 'numberofseats': '5'}
NoneType: None
2019-07-26 10:24:10 ERROR (SyncWorker_3) [mercedesmejsonpy.controller] getStateOfCharge for 6DE25C138CECE3B10B called
NoneType: None
2019-07-26 10:24:10 ERROR (SyncWorker_3) [mercedesmejsonpy.controller] API_ENDPOINT: https://api.mercedes-benz.com/experimental/connectedvehicle/v1, APT_VEHICLES: vehicles, car_id: 6DE25C138CECE3B10B, api: stateofcharge
NoneType: None
2019-07-26 10:24:10 ERROR (SyncWorker_3) [mercedesmejsonpy.controller] url: https://api.mercedes-benz.com/experimental/connectedvehicle/v1/vehicles/6DE25C138CECE3B10B/stateofcharge, headers: {'content-type': 'application/json', 'Authorization': 'Bearer d0c68dd4-c939-4a0f-8cf8-xxxxxxxxxxxx'}, proxies: None
NoneType: None
2019-07-26 10:24:12 ERROR (SyncWorker_3) [mercedesmejsonpy.controller] res.json: {'reason': 'Invalid response was retrieved from High Mobility. No state of charge information is available.', 'code': 500}
NoneType: None
2019-07-26 10:24:12 ERROR (SyncWorker_3) [mercedesmejsonpy.controller] Connection failed with http code 500
NoneType: None
2019-07-26 10:24:13 ERROR (MainThread) [homeassistant.setup] Error during setup of component mercedesmebeta
File "/usr/local/lib/python3.7/dist-packages/homeassistant/setup.py", line 156, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/usr/lib/python3.7/concurrent/futures/thread.py", line 57, in run
File "/home/pi/.homeassistant/custom_components/mercedesmebeta/__init__.py", line 165, in setup
mercedesme_api = Controller(auth_handler, scan_interval)
File "/home/pi/.homeassistant/deps/lib/python3.7/site-packages/mercedesmejsonpy/controller.py", line 156, in __init__
self.load_cars()
File "/home/pi/.homeassistant/deps/lib/python3.7/site-packages/mercedesmejsonpy/controller.py", line 205, in load_cars
car.stateofcharge = self.get_state_of_charge(car.id)
File "/home/pi/.homeassistant/deps/lib/python3.7/site-packages/mercedesmejsonpy/controller.py", line 312, in get_state_of_charge
result = stateofcharge.get("stateofcharge")
AttributeError: 'NoneType' object has no attribute 'get'
Then I query the data according to the connection API(https://developer.mercedes-benz.com/apis/connected_vehicle_experimental_api/docs), some api response is valid,
$ curl -X GET "https://api.mercedes-benz.com/experimental/connectedvehicle/v1/vehicles" \
> -H "accept: application/json" \
> -H "authorization: Bearer 20cf9050-2217-4a89-bcd6-xxxxxxxxxxxx"
[{"id":"6DE25C138CECE3B10B","licenseplate":"S-GG-613","finorvin":"1HMA8C654H2B0B551"}]
$ curl -X GET "https://api.mercedes-benz.com/experimental/connectedvehicle/v1/vehicles/6DE25C138CECE3B10B" \
{"id":"6DE25C138CECE3B10B","licenseplate":"S-GG-613","salesdesignation":"E 400 4MATIC Limousine","finorvin":"1HMA8C654H2B0B551","nickname":"mmueller","modelyear":"2017","colorname":"iridiumsilber metallic","fueltype":"Benzin","powerhp":"333","powerkw":"245","numberofdoors":"5","numberofseats":"5"}
and some api response was invalid, such as stateofcharge and doors, the response was following:
$ curl -X GET "https://api.mercedes-benz.com/experimental/connectedvehicle/v1/vehicles/6DE25C138CECE3B10B/stateofcharge" \
{"reason":"Invalid response was retrieved from High Mobility. No state of charge information is available.","code":500}
$ curl -X GET "https://api.mercedes-benz.com/experimental/connectedvehicle/v1/vehicles/6DE25C138CECE3B10B/doors" \
{"reason":"Invalid response was retrieved from High Mobility. No doors information is available.","code":500}
from the docs I know the code 500 means: An error occurred on the server side, e.g. a required service did not provide a valid response.
Do you know how to get the valid response?
Thanks very much!
Hi @rangerzhou,
Looks like a bug on the server side and you should ask the Mercedes dev team about this. You can find the email address on their developer website.
OK, I have already contact them through the link https://developer.mercedes-benz.com/support, hope they can give me the answer.
Thanks!
Thanks to all who share (part of) their config.
I’m too much of a novice to get it working though. Can someone post clear instructions from a to z on how to add something like this: Mercedes Me Component
I have the mercedesme component already working and the default sensors are present.
Is it possible to get some additonal attributes for:
supplybatteryvoltage, batteryState
Should be available according to this:
Also warninglowbattery does not appear for me under warningenginelight?
Hi @plantoschka,
please excuse my late response… it’s vacation season
supplybatteryvoltage and warninglowbattery are attributes of the ‘Range electric’ electric sensor.
I’ll add batteryState.
BR
Rene
Quick question @ReneNulschDE. I have taken a quick look but can’t find the answer
My daughter is in the US and has a Merc - does this component work over there?
No, don’t work.
Thank you.
I’ll just have to get her to move back to the UK …Though she will probably want to borrow my car if she did that
