Mercedes Me Component
Hello @ReneNulschDE
I have enabled auxheat in client.py with:
        car.auxheat = self._get_car_values(
            c, car.finorvin, Auxheat(), AUX_HEAT_OPTIONS, update_mode)
All attributes are shown, but when I start aux heat it shows only one or two of the attributes:
auxheat3a
Anything I can help to enable auxheat working correctly?
Thanks, Markus
Hi Markus,
This just old code from the old component. But you can help. I have no car with AuxHeat.
  1. Switch on the save to file mode to true. see https://github.com/ReneNulschDE/mbapi2020/blob/43161ff9124008a2b32f9a21e03920a13f3ab24b/custom_components/mbapi2020/client.py#L47
  2. restart HA, wait few minutes, start the auxheat on your mobile phone.
  3. send me the jsons out of the messages folder in the custom_components/mbapi2020.
Then I can check what needs to be adjusted.
BR
Rene
Hi Rene,
i think this has been discussed some days ago but i noticed that the state precondActive seems to be still broken. Starting precondition and the state attribute always returns false.
I have published a new version 0.4.0.
New sensors:
  • Aux Heat Status (Thanks: @danielrheinbay)
  • oilLevel
New switch:
  • AuxHeat
New Lock
  • Lock (with Pin support if the pin is not stored in the integration options, restart required if you remove or add a pin the integration options)
New Services
  • Auxheat_start
  • Auxheat_stop
Changes:
Breaking changes:
  • Hopefully none :slight_smile:
Not solved yet:
  • precondActive
  • PreCond-Now does not work for older cars, we need to implement Precond-Immediate
Others:
  • I have initiated the onboarding process to HACS. Waiting to get the Brands, Wheels and HACS merged.
Auxheat works for me now. Thanks Rene!
Wow, please share this ā€žCardā€œ ā€¦THX uwe
Thanks again RenƩ for your excellent work on this.
Today I was frustrated that the Mercedes app did not notify my that my window apparently was open, so I wondered, why canĀ“t I automate this myself. My thought was that I trigger a notification based on the ignition being off and when the window or lock open. The below code is what I was thinking of, but I could not find any documentation on the ignition_state, so itĀ“s based on the states I noticed. Has anyone tried this and a better way or suggestions?
- id: car_window_notification
  alias: Car window open notification
  initial_state: true
    - platform: state
      entity_id: sensor.xxxxxxx_ignition_state
      to: '0'
      for:
        minutes: 1
  condition:
    condition: not
    conditions:
      - condition: state
        entity_id: binary_sensor.xxxxxxx_windows_closed
        state: 'On'
    - service: notify.mobile_app_rene_s_iphone_11
        message: 'Car window open'
            url: https://www.car-brand-names.com/wp-content/uploads/2015/05/Mercedes-symbol.jpg
- id: car_lock_notification
  alias: Car unlocked notification
  initial_state: true
    - platform: state
      to: '0'
      for:
        minutes: 1
  condition:
    condition: not
    conditions:
      - condition: state
        entity_id: sensor.xxxxxxx_lock
        state: '2'
        message: 'Car unlocked'
here are the values
  • Ignition state
    Internal Name: ignitionstate
    Values     Description_short     Description_long
    "0"        "lock"                "Ignition lock"
    "1"        "off"                 "Ignition off"
    "2"        "accessory"           "Ignition accessory"
    "4"        "on"                  "Ignition on"
    "5"        "start"               "Ignition start"
based on MBSDK-CarKit-iOS/MBCarKit/MBCarKit/Common/Enums/Status/EngineTypes.swift at cbe02fc1322a6e7278b5ad1a3faafde2f36177c4 Ā· mercedes-benz/MBSDK-CarKit-iOS Ā· GitHub
I like your approach. Other option could be to measure the distance between your phone and the car.
{{ distance('device_tracker.phone1', 'device_tracker.yourcar_device_tracker') }}
Nice one! That would however only work if you were the only one using the car. In my case itā€™s me or my wife.
This you could solve with the closest function. see https://www.home-assistant.io/docs/configuration/templating/
You learn something new every day! definitely worth a shot! Thanks!
I love this component and it really works well, but I do see comments mentioning some sensors, etc. that I donā€™t see, which Iā€™m sure is to do with my subscriptions.
Is there a guide which says which APIs and which services you need to subscribe to for the various devices and sensors?
Iā€™ve subscribed to the following APIs:
  • Electric Vehicle Status BYOCAR
  • Fuel Status BYOCAR
  • Vehicle Lock Status BYOCAR
  • Vehicle Status BYOCAR
In terms of Mercedes subscriptions I have:
  • Vehicle Setup
Are there any other APIs I should be subscribing to, or any other services?
What would the Vehicle Monitoring, Remove & Navigation Services, and Stolen Vehicle Help give me that I donā€™t already get?
I canā€™t see things like charging status or location.
Hi @DerekO,
this component does not use the BYOD api currently, my component is imitating the mobile app. You should see all sensors that are available in the MercedesME App (US/CA: MercedesME Connect). Please check the service description of the additional services in the app as this depends by region/country/car.
Vehicle Setup is the core and enables most of the services.
But let me try to answer it high level:
Vehicle Monitoring = Location data is available (you could use the device tracker in HA)
Remote & Navigation Services = Focus on services around electric cars and charging
What do you miss?
BTW: If you would like to use the official API then @Giorgio_Ravera has done a lot of work. please check the posting in this thread around Octā€™ 2020.
Scroll up or klick Mercedes Me Component
thx holger, canā€™t find the pic without values ā€¦ yaml works well! thx again
Hi from Sydney Australia here. What settings should I be using for LOCALE and COUNTRY CODE for Australia/Asia Pacific?
I have added the integration successfully and it seemed to connect ok with en-AU , AU but no entities are showing up even after a HA restart.
Any Ideas?
what mobile app do you use in Australia?
BR
Rene
Great work on the new update. For some reason I donā€™t seem to have the lock. Iā€™m trying to trouble shoot the cause. If I figure it out Iā€™ll come back to you.
Rene,
Which json value are you looking for to build the lock? I tried calling the door_lock service and received the following.
ā€œVIN unknown or feature not availabe for this car.ā€
Strange because it worked previously. In fact I had created my own lock template which worked perfectly
 lock:
     value_template: "{{ is_state('binary_sensor.la221804_lock_status', 'off')}}"
     lock:
       service: mbapi2020.doors_lock
         vin: "{{ states.sensor.la221804_car.attributes.vin  }}"
     unlock:
       service: mbapi2020.doors_unlock
