The integration stopped working for me at some point, so I removed the integration and the HACS component, removed the authentication, and re-installed.
When setting up, I keep getting “Unknown error occured”.
This is the result from the logs:
Logger: aiohttp.server
Source: custom_components/mbapi2020/client.py:67
Integration: MercedesME 2020 (documentation, issues)
First occurred: 4:36:31 PM (3 occurrences)
Last logged: 4:36:45 PM
Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 219, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 137, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 166, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 62, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 111, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 252, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 325, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/config/custom_components/mbapi2020/config_flow.py", line 74, in async_step_user
client = Client(session=session, hass=self.hass, region=user_input[CONF_REGION])
File "/config/custom_components/mbapi2020/client.py", line 67, in __init__
self.__lock = RLock()
File "/usr/local/lib/python3.9/multiprocessing/context.py", line 73, in RLock
return RLock(ctx=self.get_context())
File "/usr/local/lib/python3.9/multiprocessing/synchronize.py", line 187, in __init__
SemLock.__init__(self, RECURSIVE_MUTEX, 1, 1, ctx=ctx)
File "/usr/local/lib/python3.9/multiprocessing/synchronize.py", line 57, in __init__
sl = self._semlock = _multiprocessing.SemLock(
FileNotFoundError: [Errno 2] No such file or directory
