I can reproduce the problem. Looks like MB has changed the Authentication again. (like every november :-() - Its just a minimum version update - should be easy to fix
Give me some time to prepare a new version.
BR
Rene
BR
Rene
it stopped working for me also. But now i have deleted the integration and i reinstalled but unable to connect with email. i get an error. also before download from hacs i see up on the left: āvalidate with HACS failingā
I have published a new version 0.6.9.
Bugfix:
Onboarding error: HTTPClientException - 418 - Iām not a teapot
Canāt connect to MB APIs; Retrying in background
Minimum HA-version: 2022-11
Special ask to the US users: Do you see the same problem?
BR
Rene
Upgraded and resolved. Thanks so much!
Great, it works now.
Thank you
Hi, I posted an issue on the GitHub but found the discussion here. Iām getting the āUnknown Error Occurredā as above after updating to 0.6.9
I am in North America
I have published a new version 0.6.10 to make the needed changes for the US-Region too.
Bugfix:
BR
Rene
Hi Rene,
I have been seeing the attached error for quite a while now. Iāve now updated to 0.6.10 and still have the same error. Iām in the UK.
Do you get this error continuously?
I would propose that you stop HA, delete the file .mercedesme-token-cache in your HA-config folder. Then start HA and reonboard the integration.
BR
Rene
Super thatās fixed it. Thanks for your prompt help Rene
This worked for my issue. Thank you!
Today is my last day with the employer that provided me with an EQC for the last two years.
I want to say a huge thank you to @ReneNulschDE not only for providing an excellent HA component but for giving up his time to support those of us who use it.
I also want to thank the other contributors to this topic who have helped so much to implement the component.
Next, I will have a Polestar 2, which is has a very basic App and no HA component or integration
Good luck everyone and thanks for everything.
Rich
Hi!
I have published a minor version update v0.6.11.
Bugfix Release:
minimum HA-version: 2022.11.0
Thanks to appit-online
Hi Rene,
Tank you very much for this amazing integration.
I have a 250e car with preheat fonction and i search to have a switch for expose to Alexa or Google Home.
Can you give me some tips to implamente a switch ? (i have never modify a component)
I have try with services tab to check and it works.
But i donāt know how to create a similar fonction but in switch like the lock button.
Tank you very much again for all your work.
Hi @Jillian,
Thanks and welcome to the club.
Not sure if I got your question right. If you look for a way to implement the services-call with a switch then the āswitch-templateā is a good starting point. With that you can create a switch and could execute services-calls.
If you look for general voice assistant integration, I would propose that you look around in the forum. This component is not special and just uses the HA-defaults.
BR
Rene
BTW: Here is an example for a āLOCKā that is using the same template approach
yes, you just need to create sensors to extract the attributes you need.
the code is a bit long because I put some colors based on the status of some sensors
type: picture-elements
image: /local/FG135JH.png
style: |
ha-card {
--ha-card-border-radius: 5px;
border: 1px solid #ffee58;
elements:
- type: custom:button-card
icon: mdi:gas-station-outline
color_type: icon
entity: sensor.fg135jh_fuel_level
show_state: true
show_name: false
state:
- value: 5
operator: <
color: '#FF0000'
- value: 10
operator: <=
color: '#ff6600'
- value: 30
operator: <=
color: '#ffcc00'
- value: 40
operator: <=
color: '#FFFF00'
- value: 50
operator: <=
color: '#ccff33'
- value: 65
operator: <=
color: '#e1ff00'
- value: 85
operator: <=
color: '#66ff33'
- value: 90
operator: <=
color: '#4bff0f'
styles:
card:
- width: 125px
- height: 80px
- background-color: rgba(0, 0, 0, .1)
label:
- font-color: '#ffee58'
state:
- color: white
- transform: translate(20%, -70%) scale(0.8, 0.6)
icon:
- transform: translate(-60%, 20%) scale(0.7, 0.7)
- animation: |
var blink=states['sensor.fg135jh_fuel_level'].state;
if (blink<= '15' ) return 'blink 3s linear infinite'
style:
left: 15.8%
top: 12%
template: background_glass
entity: sensor.fg135jh_km_range
show_name: false
show_icon: false
show_state: false
show_label: true
layout: icon_label
label: |
[[[ return ' ' + states['sensor.fg135jh_km_range'].state + ' km'; ]]]
state:
- value: 20
operator: <=
color: red
- value: 100
operator: <
color: yellow
- value: 100
operator: '>='
color: green
styles:
card:
- width: 200px
- height: 50px
label:
- transform: translate(-15%, 0%) scale(0.7, 0.5)
icon:
- transform: translate(50%, -0%) scale(0.6, 0.6)
style:
left: 7%
top: 7%
icon: mdi:car-traction-control
color_type: icon
entity: sensor.fg135jh_odometer
show_state: true
show_name: false
styles:
card:
- width: 150px
- height: 80px
label:
state:
- color: white
- transform: translate( -30%, -70%) scale(0.8, 0.6)
icon:
- transform: translate(-55%, 10%) scale(0.5, 0.4)
style:
left: 45.5%
top: 12%
icon: mdi:clock-time-four-outline
entity: sensor.fg135jh_service_interval
show_name: false
show_state: false
show_label: true
layout: icon_label
label: >
[[[ return 'service in: ' +
states['sensor.fg135jh_service_interval'].state + ' days'; ]]]
state:
- value: 20
operator: <=
color: red
- value: 100
operator: <
color: yellow
- value: 100
operator: '>='
color: green
styles:
card:
- width: 200px
- height: 50px
label:
- font-size: 10px
- transform: translate(-15%, -0%) scale(1.1, 0.8)
icon:
style:
left: 70%
top: 5.5%
entity: binary_sensor.fg135jh_engine_light_warning
show_header_toggle: false
state_color: true
state:
- value: 'off'
styles:
icon:
- color: rgb(0, 255, 17)
- background-color: rgba(255, 255, 255, 0.01)
- value: 'on'
styles:
icon:
- color: rgba(252, 232, 50, 0.99)
style:
left: 57%
top: 17.5%
width: 12%
entity: binary_sensor.fg135jh_tire_warning
state_color: true
state:
- value: 'off'
styles:
icon:
- value: 'on'
styles:
icon:
style:
left: 66.5%
top: 17.5%
width: 12%
entity: binary_sensor.fg135jh_low_brake_fluid_warning
state_color: true
state:
- value: 'off'
styles:
icon:
- value: 'on'
styles:
icon:
style:
left: 76%
top: 17.5%
width: 12%
entity: binary_sensor.fg135jh_low_coolant_level_warning
state_color: true
state:
- value: 'off'
styles:
icon:
- value: 'on'
styles:
icon:
style:
left: 85.5%
top: 17.5%
width: 12%
entity: binary_sensor.fg135jh_low_wash_water_warning
state_color: true
state:
- value: 'off'
styles:
icon:
- value: 'on'
styles:
icon:
style:
left: 95%
top: 17.5%
width: 12%
entity: sensor.fg135jh_starter_battery_state
state_color: true
state:
- value: 0
styles:
icon:
- width: 25%
- value: 1
styles:
icon:
- width: 20%
- color: yellow
- animation: blink 2s linear infinite
- value: 2
styles:
icon:
- width: 30%
- color: red
- animation: blink 0.5s linear infinite
- value: 3
styles:
icon:
- width: 50%
- color: brown
- value: 4
styles:
icon:
- width: 50%
- color: blue
style:
left: 38%
top: 62%
- type: state-label
entity: sensor.fg135jh_tire_pressure_front_right
style:
transform: translate(-50%, -50%) scale(0.8, 0.8)
color: lightgrey
left: 38%
top: 32%
- type: state-label
entity: sensor.fg135jh_tire_pressure_rear_right
style:
color: lightgrey
left: 84%
top: 32%
- type: state-label
entity: sensor.fg135jh_tire_pressure_front_left
style:
transform: translate(-50%, -50%) scale(0.7, 0.7)
color: lightgrey
left: 38%
top: 90%
- type: state-label
entity: sensor.fg135jh_tire_pressure_rear_left
style:
color: lightgrey
left: 84%
top: 90%
entity: sensor.fg135jh_lock_front_left
state_color: true
state:
- value: closed
styles:
icon:
- value: open
styles:
icon:
- color: red
style:
left: 61%
top: 83%
width: 10%
entity: sensor.fg135jh_lock_front_right
state_color: true
state:
- value: closed
styles:
icon:
- value: open
styles:
icon:
- color: red
style:
left: 61%
top: 38%
width: 10%
entity: sensor.fg135jh_lock_rear_left
state_color: true
state:
- value: closed
styles:
icon:
- value: open
styles:
icon:
- color: red
style:
left: 68%
top: 83%
width: 10%
entity: sensor.fg135jh_lock_rear_right
state_color: true
state:
- value: closed
styles:
icon:
- value: open
styles:
icon:
- color: red
style:
left: 68%
top: 38%
width: 10%
entity: sensor.fg135jh_lock_trunk
state_color: true
state:
- value: closed
styles:
icon:
- value: open
styles:
icon:
- color: red
style:
left: 95%
top: 60%
width: 10%
entity: sensor.fg135jh_window_front_left
state_color: true
state:
- value: closed
styles:
icon:
- value: open
styles:
icon:
- color: red
style:
left: 56%
top: 90%
width: 10%
entity: sensor.fg135jh_window_front_right
state_color: true
state:
- value: closed
styles:
icon:
- value: open
styles:
icon:
- color: red
style:
left: 56%
top: 31%
width: 10%
entity: sensor.fg135jh_window_rear_left
state_color: true
state:
- value: closed
styles:
icon:
- value: open
styles:
icon:
- color: red
style:
left: 73%
top: 90%
width: 10%
entity: sensor.fg135jh_window_rear_right
state_color: true
state:
- value: closed
styles:
icon:
- value: open
styles:
icon:
- color: red
style:
left: 73%
top: 31%
width: 10%
entity: sensor.fg135jh_lock_fuel_hood
icon: mdi:fuel
state_color: true
state:
- value: open
styles:
icon:
- value: closed
styles:
icon:
- color: red
style:
left: 85%
top: 39%
width: 10%
icon: mdi:car-brake-parking
color_type: icon
entity: sensor.fg135jh_parking_brake
show_state: true
show_name: false
styles:
card:
- width: 150px
- height: 50px
- background-color: rgba(0, 0, 0, 0)
name:
- transform: translate(50%, -150%)
state:
- font-size: 10px
- transform: translate(100%, -150%)
state:
- value: closed
styles:
icon:
- width: 25%
- color: rgba(0, 255, 17, 0.4)
- value: open
styles:
icon:
- width: 25%
- color: rgba(255, 0, 0, 1)
style:
left: 5%
top: 35%
icon: mdi:car-door
color_type: icon
entity: sensor.fg135jh_windows_state
show_state: true
show_name: false
styles:
card:
- width: 150px
- height: 50px
name:
state:
- font-size: 10px
state:
- value: closed
styles:
icon:
- width: 25%
- value: open
styles:
icon:
- width: 25%
style:
left: 5%
top: 47%
icon: mdi:car-door-lock
color_type: icon
entity: sensor.fg135jh_door_lock
show_state: true
show_name: false
name: sensore da trovare
styles:
card:
- width: 150px
- height: 50px
name:
state:
- font-size: 10px
state:
- value: closed
styles:
icon:
- width: 25%
- value: open
styles:
icon:
- width: 25%
style:
left: 5%
top: 58%
icon: mdi:car-info
color_type: icon
entity: sensor.fg135jh_lock_status
show_state: true
show_name: false
styles:
card:
- width: 150px
- height: 50px
name:
state:
- font-size: 10px
state:
- value: closed
styles:
icon:
- width: 25%
- value: internal lock
styles:
icon:
- width: 25%
- color: rgba(255, 255, 0, 1)
- value: open
styles:
icon:
- width: 25%
style:
left: 5%
top: 70%
icon: mdi:map-marker
color_type: icon
entity: device_tracker.mercedes
show_state: true
show_name: false
styles:
card:
- width: 150px
- height: 50px
name:
state:
- font-size: 10px
state:
- value: home
styles:
icon:
- width: 25%
- value: not_home
styles:
icon:
- width: 25%
- value: lavoro
styles:
icon:
- width: 25%
style:
left: 5%
top: 85%
- type: state-label
entity: sensor.mercedes_geocoded_location
style:
transform: translate(-40%, -50%) scale(0.7, 0.6)
color: lightgrey
left: 35%
top: 97.5%
thanks a lot.
hi @ReneNulschDE
I have a error message like that:
Logger: homeassistant.setup
Source: setup.py:192
First occurred: 16:58:13 (1 occurrences)
Last logged: 16:58:13
Setup failed for custom integration mbapi2020: Unable to import component: cannot import name 'US_CUSTOMARY_SYSTEM' from 'homeassistant.util.unit_system' (/usr/src/homeassistant/homeassistant/util/unit_system.py)
could you help me to resolve this pb?
thanks
I ā fund the soluceā¦ this was the version of HAā¦
