i have a RGB light wich is separated in 3 channels: red, entity , green and blue. I create a template to control it with the rgb wheel and it works fine but when i try to set the brightness level it regulate all channel with same level changing to color to white. Switching back to color wheel and selecting light change to right color ibut at full brightness.
Ho can i say to HA to regulate brightness only in the active color?
Here the code:
light:
lights:
dysl30e58630342335_rgb:
friendly_name: "Lampada TEST RGB"
value_template: "{% if is_state('light.dysl30e58630342335_red', 'on')
or is_state('light.dysl30e58630342335_green', 'on')
or is_state('light.dysl30e58630342335_blue', 'on') %}
on {% else %} off {% endif %}"
rgb_template: (
{{ state_attr('light.dysl30e58630342335_red', 'brightness')|d(0,true)|int }},
{{ state_attr('light.dysl30e58630342335_green', 'brightness')|d(0,true)|int }},
{{ state_attr('light.dysl30e58630342335_blue', 'brightness')|d(0,true)|int }},
turn_on:
service: light.turn_on
entity_id: light.dysl30e58630342335_red, light.dysl30e58630342335_green, light.dysl30e58630342335_blue
turn_off:
service: light.turn_off
set_level:
action: light.turn_on
brightness: "{{ brightness }}"
set_rgb:
- service: light.turn_on
brightness: "{{ r }}"
entity_id: light.dysl30e58630342335_green
brightness: "{{ g }}"
entity_id: light.dysl30e58630342335_blue
brightness: "{{ b }}"
