Currently, there are several integrations part of core to work with the FRITZ!Box. I propose to merge at least the fritz
and the fritzbox_netmonitor
integrations. Both go back to the same fritzconnection
library. Apparently, some work on fritz
has been started to add a sensor. Fully bringing over the sensor from fritzbox_netmonitor
would make this integration redundant.
Advantages would be:
- less confusion for users which integration to use for what
- simpler documentation
- no need to also implement config flow for
fritzbox_netmonitor
