Hoping someone can help me w/ merging templates in button-card. I made an issue here describing my problem: Merge styles in templates · Issue #1453 · UI-Lovelace-Minimalist/UI · GitHub
Here is the info from that issue:
Most likely my setup is just wrong - I am having 2 templates and I want to have them both apply styles based on different things. However sometimes all the styles from one or the other or used, or I get different results based on template order, or if I use the id
functionality to “merge” states. However I’m not sure how this applies to styles.
I have a card based on a light entity
type: "custom:button-card"
template:
- card_room
- yellow_device_on
- red_climate_problem_on
entity: light.office_light
icon: mdi:controller
one template applies styles to different places on the card:
yellow_device_on:
state:
- styles:
icon:
- color: "rgba(var(--color-yellow),1)"
label:
- color: "rgba(var(--color-yellow-text),1)"
name:
img_cell:
- background-color: "rgba(var(--color-yellow), 0.2)"
card:
- background-color: "rgba(var(--color-background-yellow),var(--opacity-bg))"
value: "on"
another JUST modifies the label
red_climate_problem_on:
label: '[[[ return states[variables.temperature_entity].state + "°F - " + states[variables.humidity_entity].state + "%" ]]]'
state:
- styles:
label:
- color: "rgba(var(--color-red-text),1)"
operator: template
value: >
[[[ return states[variables.temperature_entity].state > 80 || states[variables.humidity_entity].state > 80 ]]]
#id: "on"
triggers_update:
- "[[[ return variables.temperature_entity; ]]]"
- "[[[ return variables.humidity_entity; ]]]"
I’d like the red label template to override just the template of the yellow one, however the yellow one takes precedence
Swapping order of the templates produces same result.
If i use same id
on both, then:
if the order is
- yellow_device_on
If i swap order, it even affects not related cards
I’d like it to look like this:
