Did you try my answer from this?
Help using the new Trigger Selector (2023.12) in Blueprint - #2 by Sir_Goodenough.
What you have is some hybrid mess. I believe the whole trigger has to be in the input, ID’s and all, and you add the !input key in the trigger area as a list item.
What you have in your example should work with a text !input.
If this suggestion solves your problem, please consider clicking the solution button to close the thread.
